DRC Vehicle dimensions
asked 2013-04-09 11:49:32 -0600
Hello, We have several issues regarding the DRC vehicle and DRC simulator 2.3 :
a. Control issues
  1. The DRC vehicle and the golf cart controllers either not respond in the DRC simulator 2.3, or respond very slowly. We reported this issue on answers.gazebosim.org, and an issue was opened in bitbucket. http://answers.gazebosim.org/question/2254/drc-vehicle-controller-does-not-respond-or/
  2. The handbrake command does not respond from the terminal (since DRC simulator 2.3)
  3. When trying to manually lower the handbrake with Atlas, the handbrake jumps back to the initial position.
  4. There is still no steering wheel in the DRC vehicle. Therefore, it is impossible to drive the vehicle with atlas.
b. Geometry issues 1. Is it possible to remove the side rails? As you can see the rails block the entrances, and make it very difficult to egress the vehicle.
view pic in link
view pic in link
  1. Lower the height of the seat . The seat is still very high (the seat is at pelvis height) and it makes entering the vehicle very difficult, due to the steering wheel.
  2. The upper frame is too small, and when entering the vehicle the broad shoulders of the robot collide with the frame. view pic in link
  3. The floor of the vehicle is crowded, there isn't enough "leg room". view pic in link
ROBIL Team
I can't answer all your questions but can offer two helpful points. If you set the handbrake value to 0.1, it can get the car moving. This is probably a plugin error where they check for >0.0; so setting it to open doesn't work. Also, there are no side rails in the collision geometry; the Atlas robot cannot collide with it (also no overhead rails, for that matter), so it cannot impede your movement.
klowrey gravatar imageklowrey ( 2013-04-09 12:00:43 -0600 )edit
answered 2013-07-23 19:44:20 -0600
These issues have been fixed in recent versions of drcsim and the polaris model in gazebo_models.
Asked: 2013-04-09 11:49:32 -0600
Seen: 449 times
Last updated: Jul 23 '13
