Running code in loop inside gazebo-ros plugin
asked 2019-06-25 02:17:51 -0500
kumpakri gravatar image
Any time I have used gazebo-ros plugin of any type, I would always define an update function that is called on every world update and but the code I need to run there.
                                boost::bind(&MyPlugin::onUpdate, this));
But now I need the code to be run even if the simulation is paused. What can I use to achieve this?
answered 2019-06-25 06:20:58 -0500
chapulina gravatar image
Gazebo doesn't offer any periodic callbacks on the server which work on paused mode. But you should be able to implement your own by spinning a new thread which has a while loop. Just be careful not to call any physics functions from that thread, especially non-const functions.
Asked: 2019-06-25 02:17:51 -0500
Seen: 52 times
Last updated: Jun 25
