Integral tie-back in AtlasPlugin.cpp seems wrong - causes control glitches
asked 2013-04-09 18:22:28 -0600
GoRobotGo gravatar image
updated 2013-04-09 19:28:13 -0600
hsu gravatar image
The code at roughly line 1066 in AtlasPlugin.cpp appears to be wrong. Specifically, it generally will invert the kiq_i term on a step change and saturate in the opposite of the commanded direction.
If a negative step is applied that results in a clamped force then the code can result in a kiq_i that is clamped at the positive limit. This results in a joint excursion in the opposite of the desired direction.
This is not a desired behaviour. I would recommend simply removing the problematic code.
// lock integral term to provide continuous control as system moves
// out of staturation
this->errorTerms[i].k_i_q_i = math::clamp(
        this->errorTerms[i].k_i_q_i + (forceClamped - forceUnclamped),
answered 2013-04-09 19:28:50 -0600
hsu gravatar image
please continue discussion on ticket.
Asked: 2013-04-09 18:22:28 -0600
Seen: 183 times
Last updated: Apr 09 '13
