how to create empty_world
asked 2019-07-21 11:17:00 -0600
jwonch gravatar image
updated 2019-07-22 09:03:08 -0600
chapulina gravatar image
I'm using ubuntu 16.04 and kinetic. I'm learning ROS by using a book called "Learning robotics using python" 2nd edition and using the command: ~/catkin_ws/src/chefbot_description$ roslaunch chefbot_gazebo chefbot_empty_world.launch and get the error: chefbot_empty_world.launch] is neither a launch file in package [chefbot_gazebo] nor is [chefbot_gazebo] a launch file name
Gazebo 7.0.0 on ubuntu 16.04
any hints on how to run this error down?
answered 2019-07-23 11:13:22 -0600
bhej gravatar image
updated 2019-07-23 11:14:21 -0600
You need to source your catkin workspace so ROS knows where to find your packages. This overlays your workspace on top of your environment. You need to do this for every terminal that you open.
In the terminal. change directory to your catkin workspace then source it by typing source devel/setup.bash
Alternatively, you can edit your bashrc file so you do not have to source your working environment everytime:
  1. In the terminal: gedit ~/.bashrc
  2. Scroll to the bottom and add the following line: source ~/your_catkin_workspace/devel/setup.bash
  3. Save and exit
Now ROS should be able to find your launch files each time you open a new terminal!
Asked: 2019-07-21 11:17:00 -0600
Seen: 97 times
Last updated: Jul 23 '19
