Acceleration generated incorrectly when setting force command from ROS
asked 2019-07-29 18:34:01 -0500
baymax gravatar image
I have created a simple plugin that creates a ros node, subscribes to a rostopic to receive force data and apply it to a block of unit mass in the X direction. However I am having issues with the acceleration generated when the force is set from the ros callback function. The image below shows the plots of acceleration, velocity and position in X when a force of 15N is applied to the block.
image description
When the force is set directly in the OnUpdate() function, I can see a constant acceleration as expected.
image description.
I have also attached the code to create my plugin. Am I doing something incorrectly in the callback function?
C:\fakepath\forces.cc
C:\fakepath\forces.hh
I am using gazebo 9.10 with ros kinetic on ubuntu xenial.
