Cannot use fork() with anything that links Gazebo common
asked 2019-08-08 15:51:47 -0500
Jenny B gravatar image
I'm trying to use fork to start Gazebo and another process together in a test. However, linking against gazebo_common causes the forked child process to hang. Here is a minimal example:
#include "gazebo/common/Time.hh"
int main(int argc, char** argv) {
    int pid = fork();
    if (pid == 0) {
        printf("in child process %d\n", getpid());
        exit(0);
    } else {
        printf("in parent process %d\n", getpid());
        gazebo::common::Time time;
If I run this I find that the child process never dies. If I do not include the instantiation of gazebo::common::Time then the child process dies as I would expect.
I'm using a from-source install of gazebo10 on gazebo10_10.0.0 but also saw this problem with the source install of gazebo9.
This behavior is what I would expect if there were threading in the program but I'm not including any threading in the above. Does simply linking against gazebo_common pull in something that spawns threads?
Has anyone else noticed this or can reproduce?
Thanks.
I'd also be interested in any solution for launching a process from within a Gazebo TestFixture that doesn't use fork :)
Jenny B gravatar imageJenny B ( 2019-08-09 06:09:52 -0500 )edit
This appears to have to do with the ModelDatabase singleton.
Jenny B gravatar imageJenny B ( 2019-08-23 11:12:02 -0500 )edit
answered 2019-08-09 10:49:03 -0500
chapulina gravatar image
On gazebo_ros_pkgs we're using fork() in tests. Maybe the example helps:
None of those files actually pull in any Gazebo dependencies in their headers.
Note that the gazebo_main does use fork, but I suspect that's why the process always has to escalate to sigkill for the client.
Jenny B gravatar imageJenny B ( 2019-08-12 08:03:53 -0500 )edit
answered 2019-08-09 06:29:02 -0500
This is not exactly an answer to the original question, but for anyone else encountering the same problem, I found I could use popen instead of fork and things worked (interesting since AFAIK popen uses fork underneath).
Asked: 2019-08-08 15:51:47 -0500
Seen: 51 times
Last updated: Aug 09
