Texture does not work properly
asked 2019-08-21 09:11:19 -0600
kumpakri gravatar image
I am trying to put a texture defined in PNG file to a custom made model in defined by OBJ file.
I have this folder structure with the model
model_name
├── materials
│   ├── scripts
│   │   └── model_name.material
│   └── textures
├── meshes
│   └── model_name.obj
├── model.config
└── model.sdf
image description
This is the model.sdf file content
<?xml version="1.0" ?>
<sdf version="1.6">
  <model name="model_name">
      <pose>0 0 0 0 0 0</pose>
          <mesh>
            <uri>model://model_name/meshes/model_name.obj</uri>
          </mesh>
        <surface>
            <friction>
                <ode>
                    <mu>1</mu>
                    <mu2>1</mu2>
                    <fdir1>0 0 0</fdir1>
                    <slip1>0</slip1>
                    <slip2>0</slip2>
                </ode>
            </friction>
        </surface>
          <mesh>
            <uri>model:/model_name/meshes/model_name.obj</uri>
          </mesh>
          <script>
            <uri>model://model_name/materials/scripts</uri>
            <uri>model://model_name/materials/textures</uri>
            <name>Floor0</name>
          </script>
this is the model_name.material file content
material Floor0
    technique
        pass
            texture_unit
                texture ../textures/floor0.png
                scale 1.0 1.0
And this is the resulting view in Gazebo when I launch spawn this model
image description
It is only one color (the color in the bottom left corner of the PNG file). Couriously if I change the scale in the material file, the color might change to orange (the color in the middle of the PNG file) but the color stays homogeneous.
What is happening and how do I make the Gazebo render the texture correctly?
answered 2019-08-21 11:43:34 -0600
chapulina gravatar image
The problem seems to be on the UV mapping of your OBJ file.
We usually use MTL files to set the material of OBJ meshes, see an example here. I would try to export an MTL file together with your OBJ from the modelling software you used.
Thank you! I had to make the UV map for my model inside Blender by hand following this tutorial and after that the textures applied to the model are showing correctly.
kumpakri gravatar imagekumpakri ( 2019-08-22 03:40:19 -0600 )edit
2 followers
Asked: 2019-08-21 09:11:19 -0600
Seen: 103 times
Last updated: Aug 21 '19
