including models in world file, cannot access joint in model
asked 2019-09-03 05:24:19 -0600
PeterHer gravatar image
updated 2019-09-03 07:39:19 -0600
kumpakri gravatar image
If I create a model like this and import this model in my world file, I cannot access the two joints.
MODEL: (from Gazebo tutorial)
<?xml version='1.0'?>
<sdf version='1.6'>
    <model name="mymodel">
        <static>false</static>
        <link name='chassis'>
          <pose>0 0 .1 0 0 0</pose>
          <collision name='collision'>
                <size>.4 .2 .1</size>
          <visual name='visual'>
          <collision name='caster_collision'>
            <pose>-0.15 0 -0.05 0 0 0</pose>
              <sphere>
              <radius>.05</radius>
            </sphere>
          <surface>
            <friction>
              <ode>
                <mu>0</mu>
                <mu2>0</mu2>
                <slip1>1.0</slip1>
                <slip2>1.0</slip2>
              </ode>
            </friction>
          </surface>
        <visual name='caster_visual'>
            <sphere>
            </sphere>
      <link name="left_wheel">
        <pose>0.1 0.13 0.1 0 1.5707 1.5707</pose>
            <cylinder>
              <radius>.1</radius>
              <length>.05</length>
            </cylinder>
            <cylinder>
              <radius>.1</radius>
            </cylinder>
      <link name="right_wheel">
        <pose>0.1 -0.13 0.1 0 1.5707 1.5707</pose>
            <cylinder>
              <radius>.1</radius>
            </cylinder>
            <cylinder>
              <radius>.1</radius>
            </cylinder>
      <joint type="revolute" name="left_wheel_hinge">
        <pose>0 0 -0.03 0 0 0</pose>
        <child>left_wheel</child>
        <parent>chassis</parent>
        <axis>
          <xyz>0 1 0</xyz>
        </axis>
      <joint type="revolute" name="right_wheel_hinge">
        <pose>0 0 0.03 0 0 0</pose>
        <child>right_wheel</child>
        <axis>
          <xyz>0 1 0</xyz>
        </axis>
WORLD:
<?xml version="1.0" ?>
<sdf version="1.6">
  <world name="default">
        <uri>model://sun</uri>
    <model name='mymodel'>
        <pose>0 0 0 0 0 0</pose>
                <uri>/home/test/src/simulator_world/models/my_model</uri>
        <plugin name="mymodel" filename="libmymodel.so"/>
  </world>
GAZEBO MODEL PLUGIN:
    void Load(physics::ModelPtr _model, sdf::ElementPtr _sdf)
        this->myModelPtr = _model;
        this->leftWheelJoint = myModelPtr->GetJoint("left_wheel_hinge");
Only if I put the whole model makeup in the world file I can access the Joint. Any idea why?
I have a lot of models which I want to control in the plugin. If all makeup text has to be done in the world file, I get a very large file.
All suggestions are welcome.
Thanks, Peter
answered 2019-09-03 07:47:13 -0600
The joint is not identified by the model plugin just by its name, but you need to specify also the model it belongs to. I always do it the way shown below.
std::string leftWheelJointName = this->myModelPtr->GetName() + "::left_wheel_hinge";
this->leftWheelJoint = myModelPtr->GetJoint(leftWheelJointName);
Thanks, problem solved :-)
PeterHer gravatar imagePeterHer ( 2019-09-03 11:24:05 -0600 )edit
Asked: 2019-09-03 05:24:19 -0600
Seen: 109 times
Last updated: Sep 03 '19
