models within a box are jittery. How to prevent the vibration?
asked 2019-09-30 17:31:23 -0500
I am trying to make a box that contains multiple balls. However as soon as I add a second layer of balls, the balls in the first layer begin to vibrate. Is there any specific values that i need to add to prevent this from happening.
edit: It seems that the balls do not have enough space in the lower layer and begin vibrating instead of rearranging themselves.
Thanks in advance.
probably you should set a parameter called max_depth, ex:
<collision name="collision0">
      <surface>
        <contact>
          <ode>
            <min_depth>0.01</min_depth>
          </ode>
        </contact>
     </surface>
You can check this link for a comparison between different values of max_depth
dkoung gravatar imagedkoung ( 2019-10-01 09:17:02 -0500 )edit
@dkoung Thanks for the response. I tried the following and it did not solve the problem. The issue I observed is that there is not enough space for all the balls in the lower layer and so they collide with each other instead of rearranging themselves.
adheeshenoy gravatar imageadheeshenoy ( 2019-10-01 13:01:52 -0500 )edit
Edit to my previous response: it's min_depth not max_depth, sorry.
Also try max_vel=0.0, it is maximum interpenetration error correction velocity. By setting it to 0, interpenetrating objects will not be pushed apart.
  <surface>
    <contact>
      <ode>
        <max_vel>0.0</max_vel>
      </ode>
    </contact>
  </surface>
dkoung gravatar imagedkoung ( 2019-10-02 02:46:05 -0500 )edit
@dkoung Worked like a charm. Thanks a lot!
adheeshenoy gravatar imageadheeshenoy ( 2019-10-02 16:54:46 -0500 )edit
@adheeshenoy You're welcome.
dkoung gravatar imagedkoung ( 2019-10-03 03:41:15 -0500 )edit
answered 2019-10-04 15:35:09 -0500
So the answer is: Making max_vel=0.0 and adding min_depth to a really small value like 0.01. For example:
<surface>
    <contact>
      <ode>
      </ode>
    </contact>
  </surface>
Thank you to dkoung for the answer.
Asked: 2019-09-30 17:31:23 -0500
Seen: 63 times
Last updated: Oct 04
