Not sure how to work with the contact sensor.
asked 2019-10-04 15:44:47 -0500
Hello, New to gazebo.
I am trying to add a sensor to a link and get force values. I am using a urdf. I tried the tutorial for the force torque sensor on gazebo but it didn't work. I tried the contact sensor. IT shows up in the rostopic list. However, does not show any information.
The gazebo code is here:
<gazebo reference="${name}_finger_33_sensor">
        <material>Gazebo/Black</material>
        <sensor type="contact" name="contact_sensor">
                    <always_on>true</always_on>
                    <update_rate>1.0</update_rate>
                                    <contact>
                    <collision>${name}_finger_13_sensor_collision</collision>
                    </contact>
                        <plugin name="contact_plugin" filename="libgazebo_ros_bumper.so">
                        <alwaysOn>true</alwaysOn>
                        <updateRate>8</updateRate>
                        <bumperTopicName>contact_sensor</bumperTopicName>
                    <frameName>${name}_finger_33_sensor</frameName>
I can see contact_sensor when I enter rostopic list in the terminal.This is what I get when i use rostopic echo image description
Thanks for the help in advance. If you also know how to import the data to use it in python kindly let me know.
