GetAngleImpl fails on Revolute2 joints
asked 2012-11-17 21:22:22 -0500
cga gravatar image
updated 2013-01-09 16:09:56 -0500
nkoenig gravatar image
I gather that GetAngleImpl should be used to get the first angle of a revolute2 joint.
In ODEHinge2Joint.cc that leads to a call to dJointGetHinge2Angle1(), which looks like the right helper function to calculate this angle.
However, in physics/Joint.hh GetAngleImpl seems to be wiped out:
    `protected: virtual math::Angle GetAngleImpl(int _index) const = 0;`
This leads to the following compiler complaint when I try to invoke GetAngleImpl():
`joint_state.position[0] = this->front_left_joint->GetAngleImpl( 0 ).Radian();`
gets the compiler error message:
`/usr/include/gazebo-1.2/gazebo/physics/Joint.hh: In member function ‘void gazebo::ROSModelPlugin::OnUpdate()’:`
`/usr/include/gazebo-1.2/gazebo/physics/Joint.hh:228:38: error: ‘virtual gazebo::math::Angle gazebo::physics::Joint::GetAngleImpl(int) const’ is protected`
/home/cga/drc-cmub/gazebo/models/car/car.cc:94:68: error: within this context
this->front_left_joint is a revolute2 joint. I can get velocities, but not positions.
Thanks, Chris
answered 2012-11-21 08:55:38 -0500
Erik Stoltenborg gravatar image
You can not use protected functions like that.
To get the angle(s), use gazebo::physics::joint::GetAngle(int _index).
Alternatively you can just get the child link ptr, to get the link pose (e.g.: GetChild()->GetPose().rot.GetAsEuler().x)).
I do not think ODEHinge2Joint::GetAngleImpl(...) is fully implemented. If you look at the source, it does not report the angles at all (it tries calculating for first axis only, then just returns zero).
eacousineau gravatar imageeacousineau ( 2013-01-03 01:25:11 -0500 )edit
It's fully implemented in the latest version of gazebo.
nkoenig gravatar imagenkoenig ( 2013-07-23 16:59:24 -0500 )edit
Asked: 2012-11-17 21:22:22 -0500
Seen: 270 times
Last updated: Jan 09 '13
