Can i share variable within instances of model plugin?
asked 2019-10-25 09:42:49 -0600
Boris94 gravatar image
I am spawning objects that fall into virtual bin. I created model plugin for objects, that reads their positions. From what i understand each plugin is running separately for each model a they don't share any variables.
My goal is to delete last XY spawned objects if one of them is outside of the bin. Is there any way that i can share for example boolean within all instances of plugin, so when one object is out, other objects are also aware of this? thanks
answered 2019-10-26 01:31:18 -0600
chapulina gravatar image
For this kind of functionality, I recommend you use a WorldPlugin, which has access to all objects at once.
i thought this might be best solution, going to try it on monday, thanks
Boris94 gravatar imageBoris94 ( 2019-10-26 19:39:55 -0600 )edit
Asked: 2019-10-25 09:42:49 -0600
Seen: 61 times
Last updated: Oct 26
