Rosmake missing error messages
asked 2013-04-16 07:08:29 -0600
cga gravatar image
updated 2013-04-16 07:12:50 -0600
Often rosmake does not tell me what the error is when it finds an error. In this case I am in the middle of converting an AtlasState variable to the new format, and it still has a .imu and .force_torque_sensors field. Here is the feedback from rosmake:
  /home/cga/rosf/pkgs/rstand1/main.cc:1718:25: warning: ‘sensor_msgs::CvBridge::CvBridge()’ is deprecated (declared at /opt/ros/fuerte/stacks/vision_opencv/cv_bridge/include/cv_bridge/CvBridge.h:64) [-Wdeprecated-declarations]
  /home/cga/rosf/pkgs/rstand1/main.cc:1717:7: warning: unused variable ‘i’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1719:14: warning: unused variable ‘count’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1720:7: warning: unused variable ‘ix’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1720:11: warning: unused variable ‘iy’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1720:15: warning: unused variable ‘index’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1720:22: warning: unused variable ‘index2’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1721:8: warning: unused variable ‘filename’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc: In function ‘void imageCallbackRight(const ImageConstPtr&)’:
  /home/cga/rosf/pkgs/rstand1/main.cc:1782:25: warning: ‘sensor_msgs::CvBridge::CvBridge()’ is deprecated (declared at /opt/ros/fuerte/stacks/vision_opencv/cv_bridge/include/cv_bridge/CvBridge.h:64) [-Wdeprecated-declarations]
  /home/cga/rosf/pkgs/rstand1/main.cc:1781:7: warning: unused variable ‘i’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1783:14: warning: unused variable ‘count’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1784:7: warning: unused variable ‘ix’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1784:11: warning: unused variable ‘iy’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1784:15: warning: unused variable ‘index’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1784:22: warning: unused variable ‘index2’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc:1785:8: warning: unused variable ‘filename’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc: In function ‘void DisparityCallback(const ConstPtr&)’:
  /home/cga/rosf/pkgs/rstand1/main.cc:1843:7: warning: unused variable ‘i’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/main.cc: In function ‘void Points2Callback(const ConstPtr&)’:
  /home/cga/rosf/pkgs/rstand1/main.cc:1877:37: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
  /home/cga/rosf/pkgs/rstand1/main.cc:1880:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
  /home/cga/rosf/pkgs/rstand1/main.cc: In function ‘int main(int, char**)’:
  /home/cga/rosf/pkgs/rstand1/main.cc:2098:7: warning: unused variable ‘i’ [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/atlas.h: At global scope:
  /home/cga/rosf/pkgs/rstand1/atlas.h:117:20: warning: ‘joint_names’ defined but not used [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/atlas.h:134:20: warning: ‘link_names’ defined but not used [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/atlas.h:151:15: warning: ‘joint_offset’ defined but not used [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/atlas.h:185:15: warning: ‘axis’ defined but not used [-Wunused-variable]
  /home/cga/rosf/pkgs/rstand1/atlas.h:219:15 ...
(more)
2
answered 2013-04-16 13:12:09 -0600
gerkey gravatar image
By default, rosmake only shows you the last 40 lines of compiler/linker output in error cases.
Two suggestions, in my preference order:
  1. Call make explicitly on the (first) package that's failing to build. E.g., instead of rosmake rstand1, do:
    roscd rstand1
    Then you'll get all the output. If you want to see the compile and link lines (by default CMake hides them from you), do:
    roscd rstand1
    make VERBOSE=1
    In addition to giving you all the build output, calling make on one package is faster than calling rosmake, because it doesn't try to build other packages.
  2. Go look at the logs that rosmake produces. At the end of each failed run, rosmake will say something like the following:
    [ rosmake ] Output from build of package joint_commands_gui written to:
    [ rosmake ]    /home/gerkey/.ros/rosmake/rosmake_output-20130416-110752/joint_commands_gui/build_output.log
    The build_output.log file it's pointing to will have the complete output from make.
Asked: 2013-04-16 07:08:29 -0600
Seen: 375 times
Last updated: Apr 16 '13
