Rigidly fixing a model to the world
asked 2019-11-05 12:05:50 -0600
mogumbo gravatar image
There are clear instructions here for rigidly fixing a model to the world: http://gazebosim.org/tutorials/?tut=r... Indeed, this works when you use a link called "world". It does not work if you use another name. Is there specific hardcoded behavior for "world" for some reason?
answered 2019-11-05 12:09:45 -0600
chapulina gravatar image
updated 2019-11-05 15:12:27 -0600
Yes, the keyword world is used to fix a joint to the world. If you name a model / link world, that should cause problems.
This tutorial mentions the special treatment for the world keyword. The reason why that word is reserved is that we need some way to identify a fixed inertial frame.
Thanks. Do you know of any documentation that explicitly states this name is reserved and explains the reasons why?
mogumbo gravatar imagemogumbo ( 2019-11-05 14:10:49 -0600 )edit
I added a bit more context to the answer. I hope that answers your question?
chapulina gravatar imagechapulina ( 2019-11-05 15:12:49 -0600 )edit
That's much more clear. Thank you.
mogumbo gravatar imagemogumbo ( 2019-11-05 15:43:34 -0600 )edit
Asked: 2019-11-05 12:05:50 -0600
Seen: 46 times
Last updated: Nov 05
