Model joints are giving error
asked 2013-04-16 10:31:16 -0600
skhan gravatar image
updated 2013-04-18 03:25:47 -0600
Hello, I designed model in gazebo. I was working fine by this weekend but when I ran it today, it is giving strange error. I am using Gazebo 1.6.3, ROS-Groovy and Ubuntu 12.04 LTS.
skhan@skhan:~$ gazebo ~/gazebo_ros_plugin/AccMet_Robot.world
Gazebo multi-robot simulator, version 1.6.3
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.Gazebo multi-robot simulator, version 1.6.3
Error [parser.cc:719] XML Element[link_name], child of element[parent] not defined in SDF. Ignoring.[parent]
Error [parser.cc:710] Error reading element <parent>
Error [parser.cc:710] Error reading element <joint>
Error [parser.cc:710] Error reading element <model>
Error [parser.cc:369] Unable to read element <sdf>
Error:   Could not find the 'robot' element in the xml file
         at line 59 in /tmp/buildd/ros-groovy-urdfdom-0.2.7-0precise-20130326-0224/urdf_parser/src/model.cpp
Error [parser_urdf.cc:1686] Unable to call parseURDF on robot model
Warning [parser.cc:377] SDF has no <sdf> element in file[urdf file]
Error [parser.cc:291] parse as old deprecated model file failed.
Error [parser.cc:636] Unable to read file[/home/skhan/gazebo_ros_plugin/models/AccMet_Robot/model.sdf]
Error [parser.cc:710] Error reading element <world>
Error [Server.cc:253] Unable to read sdf file[/home/skhan/gazebo_ros_plugin/AccMet_Robot.world]
Error [ConnectionManager.cc:100] Connection Manager is not running
I couldn't resolve it. Any help will be appreciated Thanks
answered 2013-04-18 00:13:35 -0600
scpeters gravatar image
updated 2013-04-18 00:17:43 -0600
We had recently made some changes the joint sdf syntax, but we decided to revert them since they would be too confusing. Try following the sdf 1.3 joint syntax, for example the double_pendulum_with_base model.
I m following that syntex. But strange thing was that before weekend it was working but when I updated my Gazebo this week its no more working. When i comment out joint part then links are working fine keeping model static.
skhan gravatar imageskhan ( 2013-04-18 02:04:11 -0600 )edit
Problem is solved I realized after updating my sdf file using gzsdf it changes from <child>finger2</child> to <child> <link_name>finger2</link_name> </child> so i converted it back. Now things are better =)
skhan gravatar imageskhan ( 2013-04-18 02:54:41 -0600 )edit
2
answered 2013-04-18 03:31:08 -0600
updated 2013-04-18 03:32:36 -0600
Problem is solved I realized after updating my sdf file using gzsdf it somehow changes from
<parent>base</parent>
<child>shoulder</child>
to
<parent>
  <link_name>base</link_name>
</parent>
<child>
  <link_name>shoulder</link_name>
</child>
I had the same problem now after an udpate. I had to fix it this way. Thanks
AndreiHaidu gravatar imageAndreiHaidu ( 2013-04-20 11:29:24 -0600 )edit
You are Welcome
skhan gravatar imageskhan ( 2013-04-23 04:42:29 -0600 )edit
answered 2013-04-17 02:28:06 -0600
Could you post your sdf file? The error seems to be this:
Cheers, Andrei
@AndreiHaidu Please check my updated question
skhan gravatar imageskhan ( 2013-04-18 02:02:15 -0600 )edit
Problem is that before weekend it was working fine but when I updated my Gazebo version its no more working. When I commented out joints part then links are working fine keeping model static.
skhan gravatar imageskhan ( 2013-04-18 02:05:16 -0600 )edit
   &lt;child&gt;finger2&lt;/child&gt;
to <child> <linkname>finger2</linkname> </child>
skhan gravatar imageskhan ( 2013-04-18 03:19:02 -0600 )edit
Asked: 2013-04-16 10:31:16 -0600
Seen: 3,205 times
Last updated: Apr 18 '13
