How to implement paralell threads on plugin
asked 2019-11-11 10:55:07 -0600
Weasfas gravatar image
I am currently working with a velodyne plugin on Gazebo. The plugins works fine, however it seems that, when the simulation starts calculating points (E.g.: I subscribe to the Pointcloud) the real time factor drops from 1.00 to 0.50 slowing deeply the whole simulation and thus affecting other services that I am testing.
Is there a way to improve this performance?
One of the ways I want to do this is by adding working threads to the plugin, but I was not able to find any documentation on this possibility. If anyone knows any info, paper or implementation about this topic it would be nice if you share it here.
Thanks in advance.
Are you using a gpu_ray sensor?
chapulina gravatar imagechapulina ( 2019-11-11 11:02:21 -0600 )edit
answered 2019-11-12 10:00:01 -0600
@chapulina provided the right direction.
To avoid the drop I followed these steps:
  1. Change the sensor type from ray to gpu_ray.
  2. Since I was using Gazebo and this plugin I needed to update Gazebo from Gazebo_7.0.0 to Gazebo_7.16.0 using the following approach provided in the section "Alternative installation". The update is to cope with this issue and this issue
Now I able to simulate three lidars (2x16 samples and 1 x64 samples with almost no time_rate variation)
Thanks for the help.
Asked: 2019-11-11 10:55:07 -0600
Seen: 57 times
Last updated: Nov 12 '19
