Multiple instances of same sensor publishing to same topic
asked 2020-01-07 03:08:46 -0600
wongrufus gravatar image
updated 2020-01-07 20:44:00 -0600
I have my simulated depth sensor configured as follows
model.sdf
    <plugin name="camera_plugin" filename="libgazebo_ros_openni_kinect.so">
      <baseline>0.2</baseline>
      <alwaysOn>true</alwaysOn>
      <!-- Keep this zero, update_rate in the parent <sensor> tag
        will control the frame rate. -->
      <updateRate>0.0</updateRate>
      <cameraName>camera_ir</cameraName>
      <imageTopicName>/camera/color/image_raw</imageTopicName>
      <cameraInfoTopicName>/camera/color/camera_info</cameraInfoTopicName>
      <depthImageTopicName>/camera/depth/image_raw</depthImageTopicName>
      <depthImageCameraInfoTopicName>/camera/depth/camera_info</depthImageCameraInfoTopicName>
      <pointCloudTopicName>/camera/depth/points</pointCloudTopicName>
      <frameName>camera_frame</frameName>
      <pointCloudCutoff>0.5</pointCloudCutoff>
      <pointCloudCutoffMax>3.0</pointCloudCutoffMax>
      <distortionK1>0</distortionK1>
      <distortionK2>0</distortionK2>
      <distortionK3>0</distortionK3>
      <distortionT1>0</distortionT1>
      <distortionT2>0</distortionT2>
      <CxPrime>0</CxPrime>
      <Cx>0</Cx>
      <Cy>0</Cy>
      <focalLength>0</focalLength>
      <hackBaseline>0</hackBaseline>
Whenever I have more than 1 sensor in my gazebo world (created through the Insert tab in the gazebo GUI), the topics published by the sensors get mixed together and the following error message appears:
I've tried adding a robotNamespace for the plugin but that does not solve the problem, the same problem persists, just with the same robotNamespace added in front of all the topics.
This answer that says using an empty robotnamespace doesn't seem to work.
answered 2020-01-09 01:48:24 -0600
updated 2020-01-09 01:49:51 -0600
The key is to not use global names for all names
      <imageTopicName>camera/color/image_raw</imageTopicName>
      <cameraInfoTopicName>camera/color/camera_info</cameraInfoTopicName>
      <depthImageTopicName>camera/depth/image_raw</depthImageTopicName>
      <depthImageCameraInfoTopicName>camera/depth/camera_info</depthImageCameraInfoTopicName>
      <pointCloudTopicName>camera/depth/points</pointCloudTopicName>
(Notice the starting / removed)
And follow the instructions here of setting up the group namespace and tf prefix.
Something along the followings in the launch file will do:
<param name="robot_description_sdf" textfile="kinect/model.sdf"/>
<group ns="kinect1">
    <param name="tf_prefix" value="kinect1_tf" />
    <node pkg="gazebo_ros" type="spawn_model" name="spawn_sdf" args="-sdf -param /robot_description_sdf -model kinect1 -x -3 -y 0 -z 1" />
</group>
<group ns="kinect2">
    <param name="tf_prefix" value="kinect2_tf" />
    <node pkg="gazebo_ros" type="spawn_model" name="spawn_sdf" args="-sdf -param /robot_description_sdf -model kinect2 -x -3 -y 1 -z 1" />
</group>
Asked: 2020-01-07 03:08:46 -0600
Seen: 60 times
Last updated: Jan 09
