cast_shadow unchecked causes crash
asked 2012-11-19 06:01:22 -0600
logicalguy gravatar image
I'm using gazebo 1.2.5 in gentoo linux. When I run gazebo with default world and add a cylinder and uncheck the cast_shadow property in somewhere in the link section of the cylinder, it causes gazebo to crash with the following error message:
Exception [Publisher.cc:79] Publishing and uninitialized message on topic[/gazebo/default/model/modify]. Required field [link[0].visual[0].name] missing.
Qt has caught an exception thrown from an event handler. Throwing exceptions from an event handler is not supported in Qt. You must reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of 'gazebo::common::Exception'
It happens every time. GDB shows no backtrace.
Thanks.
Is anybody else experiencing this bug?
logicalguy gravatar imagelogicalguy ( 2012-11-21 09:21:46 -0600 )edit
is this fixed in the dev branch?
logicalguy gravatar imagelogicalguy ( 2012-11-26 08:30:38 -0600 )edit
answered 2013-01-11 18:56:41 -0600
nkoenig gravatar image
This is the same issue: https://bitbucket.org/osrf/gazebo/issue/180/crash-when-changing-dimensions-of-box.
There is a section of code in the GUI which needs to be fixed, and this is part of it. Follow the above ticket for updates.
Asked: 2012-11-19 06:01:22 -0600
Seen: 97 times
Last updated: Jan 11 '13
