gazebo crashes on startup
asked 2013-04-21 17:30:26 -0600
DanielLC gravatar image
updated 2013-04-22 16:43:51 -0600
Running the command
gazebo
opens two blank windows, then closes them, then opens a window with a nice toolbar and stuff that looks like it's doing what it's supposed to do. A fraction of a second later, the program closes. It doesn't seem to have any sort of error message. It just has
Gazebo multi-robot simulator, version 1.7.1
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.Gazebo multi-robot simulator, version 1.7.1
Msg Publicized address: 10.0.xxx.yyy
I also tried running gzserver and gzclient on separate terminals. gzserver seems to work fine.
However, gzclient does not.
gzclient: error while loading shared libraries: liburdfdom_model.so: cannot open shared object file: No such file or directory
Edit:
Sourcing did nothing.
gazebo /usr/empty_world.sdf got me
Error [SystemPaths.cc:370] File or path does not exist["/usr/empty_world.sdf"]
Error [Server.cc:259] Could not open file[/usr/empty_world.sdf]
Error [ConnectionManager.cc:88] Connection Manager is not running
Attempting to install ROS with the instructions here failed on step 1.5:
sudo rosdep init
which gave me:
sudo: rosdep: command not found
I think this can fix your problem. Source: http://gazebosim.org/wiki/Tutorials/1.5/rosenabledmodel_plugin
source /opt/ros/groovy/setup.bash
source /usr/share/gazebo/setup.sh
export GAZEBOPLUGINPATH=~/local/lib/gazeboplugins:${GAZEBOPLUGIN_PATH}
export GAZEBOMODELPATH=~/gazeborosplugin/models:${GAZEBOMODELPATH}
gazebo ~/gazeborosplugin/<yourworldfile>.world
skhan gravatar imageskhan ( 2013-04-23 04:40:18 -0600 )edit
answered 2013-04-24 16:40:24 -0600
nkoenig gravatar image
  1. How did you install gazebo?
  2. Can you run just gzserver?
  3. If you can run gzserver, try running gzstats in another terminal while gzserver is running.
  4. gazebo /usr/empty_world.sdf is a bad command, as the resulting error messages indicate. The file /usr/empty_world.sdf does not exist.
  5. Can you provide a backtrace?
answered 2013-04-22 01:48:23 -0600
AndreiHaidu gravatar image
updated 2013-04-23 01:44:36 -0600
This liburdfdom_model.so is a library from ros it is located in /opt/ros/groovy/lib (if you are using ros groovy).
Most probably you don't have ROS installed and that is why you are getting this error. However I don't see why gazebo should depend on a ROS library. Maybe you are loading some kind of URDF model which requires ROS.
Then try fixing it by:
1) Installing ROS
or try running gazebo with an empty world with no urdfs.
2)$ gazebo /<path>/empty.world
UPDATE!!
I found a similar problem in this question. The problem was fixed by sourcing the setup.sh file:
$ source /<path>/share/gazebo/setup.sh
UPDATE!! (changed world name from empty_world.sdf to empty.world)
it tells you there is no world file in the given path, in the previous example <path> means the path on your pc to the empty.world.
As with installing ROS you may have done something wrong during the installation.
Cheers, Andrei
None of that worked. See my edit.
DanielLC gravatar imageDanielLC ( 2013-04-22 16:45:08 -0600 )edit
Asked: 2013-04-21 17:30:26 -0600
Seen: 5,733 times
Last updated: Apr 24 '13
