GUI: Rendring is very slow
asked 2013-05-03 07:19:18 -0600
igo gravatar image
updated 2013-05-03 07:20:27 -0600
HI, everybody,
I use gazebo to simulate a robot made by my labratory.But, strangely, the GUI of gzclient is quite slow. A simple world was placed into the gazebo(1.4), and the physics process is smooth with Real Time Factor hover around 1.0. However, I found that the gzclient is quite slow, and the gzclient cause a high CPU load.
About my computer: CPU: i7-3770 GPU: GTX670 Memory: 16G
and the GPU driver seems work well. I have test it with 'glxgrears', and achieved about 22000fps.
I don't understant why gzclient is such slow. the fps of the GUI is no more then 2Hz. Anybody have ideas about this?
can you check which package your libGL.so belongs to?
hsu gravatar imagehsu ( 2013-05-03 23:01:03 -0600 )edit
I am having the same issue. I am using a world file with a very small town of buildings. The GUI takes nearly a minute to load,and then the entire GUI renders at less than 5fps (including the menus). Using i7 CPU, GTX690 GPU, and 32GB of RAM. I ran glxinfo and verified that opengl is being rendered through my nvidia drivers. I also tried changing the libGL.so simlink under /usr/lib/i386-linux-gnu to point to the nvidia libGL.so instead of the mesa one. No luck.
pcdangio gravatar imagepcdangio ( 2013-05-23 12:40:42 -0600 )edit
answered 2013-08-27 16:51:31 -0600
Nick Eckenstein gravatar image
updated 2013-08-27 16:56:34 -0600
I had a big issue with this as well that I was finally able to solve. Basically, if your OpenGL is out of date or from the wrong vendor, you will end up with a massive drop in framerate. For Intel cards, you want the Open Source version, I know the latest (Mesa 9.0+) works well on 12.04.
A simple command at the terminal ($/usr/lib/nux/unitysupporttest -p) will tell you your OpenGL version. A couple of examples (Note that I have an Intel card on this machine):
BAD:
$ /usr/lib/nux/unity_support_test -p
OpenGL vendor string:   Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel(R) Sandybridge Mobile
OpenGL version string:  3.0 Mesa 8.0.4
Not software rendered:  yes
Not blacklisted:        yes
GLX fbconfig:           yes
GLX texture from pixmap:  yes
GL npot or rect textures: yes
GL vertex program:      yes
GL fragment program:    yes
GL vertex buffer object:  yes
GL framebuffer object:  yes
GL version is 1.4+:     yes
Unity 3D supported:     yes
GOOD:
OpenGL vendor string:   Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) Sandybridge Mobile x86/MMX/SSE2
OpenGL version string:  3.0 Mesa 9.0.3
GLX fbconfig:             yes
To solve read ‘Configuring your graphics card’ at the following link, the process is different depending on your graphics card vendor (AMD and Nvidia are discussed here as well):
http://steamcommunity.com/app/221410/discussions/1/882965118609963322/
For Intel cards, do the following (This is how I got my machine from the BAD to the GOOD state, the increase in rendering performance was pretty drastic):
https://support.steampowered.com/kb_article.php?ref=5452-IOSM-1474
answered 2016-08-08 06:58:47 -0600
Hasan gravatar image
I has the same issue. I installed Ubuntu , but didn't installed NVidia driver. So The problem was that i used Integrated Graphics Processor instead of discrete. Tip: don't download Nvidia driver from site. find package name for nvidia driver. It is some thing like: nvidia-current. then: sudo apt-get install nvidia-current
-1
answered 2013-07-23 18:50:14 -0600
nkoenig gravatar image
Are your meshes really complex (lots of triangles)?
2 followers
Asked: 2013-05-03 07:19:18 -0600
Seen: 5,485 times
Last updated: Aug 27 '13
