Z Offset of the grid in gazebo
asked 2013-05-20 05:32:18 -0600
peshala gravatar image
updated 2013-05-20 19:47:25 -0600
Hi all,
I just noticed that there is an z offset of the grid in gazebo. When a model is inserted this is clearly visible. image description
When I get a laser pointcloud using a tilting laser there is a similar offset visible and the robot appears to be floating; I guess there is a connection between this and the above. image description This is from rviz in ROS.
Is this a bug?
+++++ Edit +++++
world file <sdf version="1.4"> <world name="3D_odom_test">
    <!-- ground plane -->
    <!-- sun -->
    <uri>model://sun</uri>
    <!-- rover -->
    <uri>model://my_rover</uri>
</world> </sdf>
I am using gazebo 1.7.1
peshala gravatar imagepeshala ( 2013-05-20 06:00:55 -0600 )edit
Can you verify that your rover is correct? Are all the dimensions specified correctly? You can try turning on collision visualization in the gazebo GUI (under the view menu). The orange shapes should match the textured shapes.
nkoenig gravatar imagenkoenig ( 2013-05-20 23:07:02 -0600 )edit
answered 2013-05-20 13:58:05 -0600
The grid offset in gazebo is done on purpose. It's a hack to make sure the grid doesn't z-fight with the ground plane.
The grid in gazebo is not tied to the laser. What type of laser are you using (CPU or GPU)? It would also help to see your gazebo world file.
Thank you for your answer. I am using CPU laser (ros laser plugin). Also, can I know this grid offset value so that I can check whether there is any connection between laser pointcloud plane and the robot wheel plane?
peshala gravatar imagepeshala ( 2013-05-20 19:51:32 -0600 )edit
The grid you see in gazebo is very separate from the grid in rviz. You can even disable the grid in gazebo using the following SDF within your world: <scene><grid>false</grid></scene>. The grid height offset is 0.015 meters.
nkoenig gravatar imagenkoenig ( 2013-05-20 23:21:10 -0600 )edit
the rover moves on the grid in rviz but the pointcloud is below that. I will let you whether it matches with 0.015
peshala gravatar imagepeshala ( 2013-05-21 00:30:55 -0600 )edit
@nkoenig the reason for the pointcloud offset was due to an error of the laser plugin. I was using the laser plugin from simulator_gazebo (gazebo_ros_laser.cpp) and it was erroneous; gazebo_ros_laser.cpp from drcsim solved the problem.
peshala gravatar imagepeshala ( 2013-06-04 04:22:05 -0600 )edit
Hi, I am also moving polaris on the grid of gazebo but pointcloud is below the grid of rviz. I am just using model plugin of gazebo .How do i solve it ? Any help would be appreciated. Thanks!
anonymous gravatar imageanonymous ( 2014-11-13 01:42:54 -0600 )edit
Asked: 2013-05-20 05:32:18 -0600
Seen: 820 times
Last updated: May 20 '13
