Laser scanner implementation
asked 2013-05-21 12:44:45 -0600
Christoph gravatar image
updated 2013-05-21 12:45:33 -0600
Hey everyone,
I wanted to know how to add and implement a laser scanner / laser scanner plugin to my robot. The data of the scanner shall be passed to rviz by using ROS messages.
I got a Gazebo standalone installation with ROS installed afterwards.
My robot so far consists of a moveable base which I can move around through ROS cmd_vel messages. The control is implemented via a gazebo model plugin. As a first step I added a sensor to my sdf file with the data of our real laser scanner. But now I need the logic for an appropriate gazebo plugin (no point cloud).
Thanks
Christoph
sorry, I am unable to help you to answer this question. Could you please help me how to move around using cmd_vel? I am doing this step currently also. thank you
gazer gravatar imagegazer ( 2013-05-29 15:12:56 -0600 )edit
Hi! Can you make that a real question please. Because the text limit in comments is quiet low and the answer maybe interest other people too. Thanks.
Christoph gravatar imageChristoph ( 2013-05-30 03:57:51 -0600 )edit
answered 2013-05-27 08:24:49 -0600
updated 2013-05-27 08:31:29 -0600
what I did is: I installed the whole drcsim package and linked directly to the libgazebo_ros_laser.so. That may not be the best solution, but for the time being that will work for me.
Thanks for your help.
answered 2013-05-21 17:27:08 -0600
nkoenig gravatar image
Hi Nathan, I did the following: I took the code from your first link and added it to my project to get a working lib file. So far I didn't get any errors. When I loaded my model in Gazebo it crashed with the message: "Failed to load plugin PATH TO MY PLUGIN undefined symbol: _ZTIN6gazebo9RayPluginE"
Christoph gravatar imageChristoph ( 2013-05-22 09:05:06 -0600 )edit
Can you do a search in your worlds and code for "PATH TO MY PLUGIN". I think you may have cut and paste some example code without filling the correct value.
nkoenig gravatar imagenkoenig ( 2013-05-23 12:34:59 -0600 )edit
I am using absolute paths. I also have another plugin in that path which I start successfully with my model in gazebo.
Christoph gravatar imageChristoph ( 2013-05-24 11:06:59 -0600 )edit
Asked: 2013-05-21 12:44:45 -0600
Seen: 1,833 times
Last updated: May 27 '13
