trouble building gazebo_pkgs for ROS integration
asked 2013-05-30 14:02:04 -0500
I have Gazebo 1.8.0 installed on my GNU/Linux Gentoo machine and ROS Groovy. I've been meaning to use ROS to drive my Gazebo simulation, so I am eager to get ROS Groovy integration with Gazebo working. I've been using the instructions on this page as a guide.
The command I used to build all my ROS packages is $ sudo ./src/catkin/bin/catkin_make_isolated --install-space /opt/ros/groovy --cmake-args -DSETUPTOOLS_DEB_LAYOUT=OFF and all the ROS packages compiled without errors. I then used the command $ catkin_make_isolated --install and it installed nearly all the packages to my preferred location. It fails at the package gazebo_ros and gives the following error:
-- Installing: /home/ro/ros_catkin_ws/install_isolated/include/gazebo_ros/PhysicsConfig.h
Listing /home/ro/ros_catkin_ws/devel_isolated/gazebo_ros/lib/python2.7/site-packages/gazebo_ros/cfg ...
Compiling /home/ro/ros_catkin_ws/devel_isolated/gazebo_ros/lib/python2.7/site-packages/gazebo_ros/cfg/PhysicsConfig.py ...
Compiling /home/ro/ros_catkin_ws/devel_isolated/gazebo_ros/lib/python2.7/site-packages/gazebo_ros/cfg/__init__.py ...
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/python2.7/site-packages/gazebo_ros/cfg
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/python2.7/site-packages/gazebo_ros/cfg/PhysicsConfig.py
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/python2.7/site-packages/gazebo_ros/cfg/PhysicsConfig.pyc
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/python2.7/site-packages/gazebo_ros/cfg/__init__.py
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/python2.7/site-packages/gazebo_ros/cfg/__init__.pyc
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/pkgconfig/gazebo_ros.pc
-- Installing: /home/ro/ros_catkin_ws/install_isolated/share/gazebo_ros/cmake/gazebo_rosConfig.cmake
-- Installing: /home/ro/ros_catkin_ws/install_isolated/share/gazebo_ros/cmake/gazebo_rosConfig-version.cmake
-- Installing: /home/ro/ros_catkin_ws/install_isolated/share/gazebo_ros/package.xml
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/libgazebo_ros_api_plugin.so
-- Removed runtime path from "/home/ro/ros_catkin_ws/install_isolated/lib/libgazebo_ros_api_plugin.so"
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/libgazebo_ros_paths_plugin.so
-- Removed runtime path from "/home/ro/ros_catkin_ws/install_isolated/lib/libgazebo_ros_paths_plugin.so"
-- Installing: /home/ro/ros_catkin_ws/install_isolated/include/gazebo_ros/gazebo
-- Installing: /home/ro/ros_catkin_ws/install_isolated/include/gazebo_ros/gazebo/gazebo_ros_api_plugin.h
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/gazebo_ros/gazebo
-- Installing: /home/ro/ros_catkin_ws/install_isolated/lib/gazebo_ros/debug
CMake Error at cmake_install.cmake:191 (FILE):
  file INSTALL cannot find
  "/home/ro/ros_catkin_ws/src/gazebo_pkgs/gazebo_ros/scripts/gui".
make: *** [install] Error 1
  File "/home/ro/ros_catkin_ws/src/catkin/python/catkin/builder.py", line 658, in build_workspace_isolated
    number=index + 1, of=len(ordered_packages)
  File "/home/ro/ros_catkin_ws/src/catkin/python/catkin/builder.py", line 443, in build_package
    install, jobs, force_cmake, quiet, last_env, cmake_args, make_args
  File "/home/ro/ros_catkin_ws/src/catkin/python/catkin/builder.py", line 305, in build_catkin_package
    run_command(make_install_cmd, build_dir, quiet)
  File "/home/ro/ros_catkin_ws/src/catkin/python/catkin/builder.py", line 186, in run_command
    raise subprocess.CalledProcessError(proc.returncode, ' '.join(cmd))
CalledProcessError: Command '/home/ro/ros_catkin_ws/install_isolated/env.sh make install' returned non-zero exit status 2
<== Failed to process package 'gazebo_ros':
Reproduce this error by running:
==> /home/ro/ros_catkin_ws/install_isolated/env.sh make install
Command failed, exiting ...
(more)
Now when I look for the above mentioned file in my system, it does not exist. It is not even present in the OSRF repo. Is this some kind of bug, maybe?
logicalguy gravatar imagelogicalguy ( 2013-05-31 01:10:44 -0500 )edit
So, anybody out there who can help? Is this a bug or am I doing something wrong?
logicalguy gravatar imagelogicalguy ( 2013-06-05 21:43:13 -0500 )edit
Take a look at this repository. It has the latest gazebo ros integration work. https://github.com/osrf/gazeborospkgs
nkoenig gravatar imagenkoenig ( 2013-06-06 12:45:20 -0500 )edit
