Set Odometry and SetModelState
asked 2013-06-03 20:38:15 -0600
David Lu gravatar image
updated 2013-06-04 16:20:36 -0600
For repeated tests, I want to move my robot back to (0,0). I've been using SetModelState, but that does not reset the odometry. Is there a way to reset the odometry easily?
I found LAYER_POSITION2D_REQ_SET_ODOM here but it's unclear how to use it from ROS.
Edit: I'm using the basic PR2 setup in conjunction with ROS. I create an empty world and spawn a PR2 in it. The /base_odometry/odom topic is published by the /gazebo node.
what robot and which odometry are you talking about? Where do you get the odometry from, a plugin?
ffurrer gravatar imageffurrer ( 2013-06-03 21:53:37 -0600 )edit
answered 2013-06-05 15:35:02 -0600
hsu gravatar image
Hi David,
PR2 odometry information is published by a ROS odometry controller. All controllers in gazebo are loaded through a gazebo plugin that mimics the PR2 controller manager on the robot. Gazebo itself does not keep odometry information.
John
answered 2013-06-04 11:36:50 -0600
nkoenig gravatar image
Odometry information is not stored with Gazebo, unless you have a special plugin (or one of the ROS plugins has an odometry value).
Can you describe what robot you're using, and what plugins?
Updated in description above.
David Lu gravatar imageDavid Lu ( 2013-06-05 14:48:40 -0600 )edit
Asked: 2013-06-03 20:38:15 -0600
Seen: 1,567 times
Last updated: Jun 05 '13
