gazebo crashes after launched [closed]
asked 2013-06-13 10:47:16 -0500
Hugo Siles gravatar image
updated 2013-06-13 12:32:03 -0500
hsu gravatar image
Hi all: I just managed to install gazebo-1.8.6 in fedora 18, the gazebo command opens the main window, but after a few seconds it just crashes and I can see in the terminal a multiple repeated message such as:
Error: failed to compile this fragment program:
FRAG
PROPERTY FS_COLOR0_WRITES_ALL_CBUFS 1
DCL IN[0], GENERIC[0], PERSPECTIVE
DCL IN[1], GENERIC[1], PERSPECTIVE
DCL IN[2], GENERIC[2], PERSPECTIVE
DCL OUT[0], COLOR
DCL SAMP[0]
DCL SAMP[1]
DCL SAMP[2]
DCL CONST[3..8]
DCL TEMP[0..6], LOCAL
IMM[0] FLT32 {    0.0052,     5.0000,    -0.5000,     1.0000}
IMM[1] FLT32 {    0.0000,     0.2000,     1.5000,     2.5000}
IMM[2] FLT32 {    2.0000,     0.5000,     3.0000,     7.5000}
IMM[3] FLT32 {    6.5000,     1.4427,     0.0000,     0.0000}
  0: MOV TEMP[0].yz, IN[2].yxyy
  1: MOV TEMP[0].x, IN[1].wwww
  2: MUL TEMP[1].xy, IN[0].xyyy, IMM[0].yyyy
  3: MOV TEMP[1].xy, TEMP[1].xyyy
  4: TEX TEMP[1].xyz, TEMP[1], SAMP[0], 2D
  5: ADD TEMP[1].xyz, TEMP[1].xyzz, IMM[0].zzzz
  6: MAD TEMP[0].xyz, IMM[0].xxxx, TEMP[1].xyzz, TEMP[0].xyzz
  7: MOV TEMP[1].xy, TEMP[0].xyxx
  8: MOV_SAT TEMP[0].x, TEMP[0].zzzz
  9: MOV TEMP[1].z, TEMP[0].xxxx
 10: MOV TEMP[0].xyz, TEMP[1].xyzz
 11: TEX TEMP[0].xyz, TEMP[0], SAMP[1], 3D
 12: MOV TEMP[1].xyz, TEMP[1].xyzz
 13: TEX TEMP[1].xyz, TEMP[1], SAMP[2], 3D
 14: ADD TEMP[2].x, IMM[0].wwww, -CONST[8].xxxx
 15: MUL TEMP[1].xyz, TEMP[1].xyzz, TEMP[2].xxxx
 16: MAD TEMP[0].xy, TEMP[0].xyzz, CONST[8].xxxx, TEMP[1].xyzz
 17: SLT TEMP[2].x, IMM[1].xxxx, TEMP[0].xxxx
 18: DP3_SAT TEMP[3].x, CONST[7].xyzz, IN[1].xyzz
 19: POW TEMP[4].x, IN[0].zzzz, IMM[1].zzzz
 20: MUL TEMP[3].x, TEMP[3].xxxx, TEMP[3].xxxx
 21: MUL TEMP[3].x, TEMP[3].xxxx, CONST[4].yyyy
 22: MUL TEMP[5].x, IMM[2].xxxx, CONST[7].yyyy
 23: ADD_SAT TEMP[5].x, IMM[0].wwww, -TEMP[5].xxxx
 24: MUL TEMP[5].x, IMM[1].wwww, TEMP[5].xxxx
 25: MAD TEMP[5].x, TEMP[5].xxxx, TEMP[0].yyyy, IMM[2].yyyy
 26: MUL TEMP[3].x, TEMP[3].xxxx, TEMP[5].xxxx
 27: MAD TEMP[3].x, TEMP[0].yyyy, CONST[4].xxxx, TEMP[3].xxxx
 28: MAD_SAT TEMP[3].x, TEMP[4].xxxx, CONST[4].wwww, TEMP[3].xxxx
 29: MAX TEMP[3].x, IMM[1].yyyy, TEMP[3].xxxx
 30: POW TEMP[4].x, IN[2].yyyy, IMM[2].zzzz
 31: POW TEMP[5].x, IN[2].yyyy, IMM[2].xxxx
 32: MAD TEMP[6].x, CONST[3].yyyy, IN[2].yyyy, CONST[3].xxxx
 33: MAD TEMP[5].x, CONST[3].zzzz, TEMP[5 ...
(more)
edit retag flag offensive reopen merge delete
Closed for the following reason question is not relevant or outdated by yah130s
close date 2015-11-18 12:42:06.484677
What is the output of glxinfo?
nkoenig gravatar imagenkoenig ( 2013-07-23 18:39:34 -0500 )edit
