gazebo 1.6.7 in ros fuerte problems
asked 2012-11-30 04:44:19 -0500
joseescobar60 gravatar image
I'm working on ros fuerte with gazebo, yesterday i installed the version of simultaor gazebo 1.6.7 because i need to work with the contact sensors of the shadowhand and the version that i have (1.6.16) has a problem with the contactsensors, the installation was ok, but when i open my gazebo y too slow, then i try to run it in headless mode but it doesn't open it remains freeze.
When i run the gazebo normally i try to spawn the shadow hand but it doesn't appear, i don't know what is happening, someone knows what is wrong???
Runing in headless mode:
jose@ubuntu:~$ roslaunch gazebo_worlds empty_world_no_x.launch
... logging to /home/jose/.ros/log/62c8e30c-3ada-11e2-b606-e0ca942b6aa6/roslaunch-ubuntu-6429.log
Press Ctrl-C to interrupt
started roslaunch server http://ubuntu:45729/
SUMMARY
PARAMETERS
 * /rosdistro
 * /rosversion
 * /use_sim_time
NODES
    gazebo (gazebo/gazebo)
auto-starting new master
Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading' from '/usr/lib/python2.7/threading.pyc'> ignored
process[master]: started with pid [6445]
setting /run_id to 62c8e30c-3ada-11e2-b606-e0ca942b6aa6
process[rosout-1]: started with pid [6458]
process[gazebo-2]: started with pid [6472]
Gazebo multi-robot simulator, version 1.3.0
Copyright (C) 2012 Nate Koenig, John Hsu, and contributors.
http://gazebosim.org
Warning [parser.cc:362] Converting a deprecatd SDF source[/home/jose/fuerte_workspace/simulator_gazebo/gazebo_worlds/worlds/empty.world].
Set SDF value
  Version[1.2] to Version[1.3]
  Please use the gzsdf tool to update your SDF files.
    $ gzsdf convert [sdf_file]
[ INFO] [1354272041.822041146]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
Msg Waiting for master
Msg Connected to gazebo master @ http://localhost:11345
[ INFO] [1354272043.627426014, 0.001000000]: joint trajectory plugin missing <updateRate>, defaults to 0.0 (as fast as possible)
[ INFO] [1354272043.659119580, 0.024000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1354272043.728475086, 0.090000000]: Starting to spin physics dynamic reconfigure node...
answered 2013-01-11 18:23:15 -0500
nkoenig gravatar image
Gazebo is a stand-alone package. Please do not use the version of Gazebo that ships with ROS. The version within ROS is old and unsupported.
http://gazebosim.org/wiki/install describes how to install Gazebo.
Do not follow any of the Gazebo tutorials on the ROS website. They are old and unmaintained. Only use the tutorials on http://gazebosim.org/wiki
You can still use ROS Fuerte, but you should install Gazebo from the repository hosted by OSRF.
hey, i went out for a long time, i just read your anser and i installed the gazebo like you said to me, it works but the problem is when i need to work with ros and gazebo the tow applications are not bound, it works like a independient applications... any idea?
joseescobar60 gravatar imagejoseescobar60 ( 2013-01-29 10:16:09 -0500 )edit
Can you explain your problem in more detail? Gazebo has always been a stand alone application (not tied to ROS).
nkoenig gravatar imagenkoenig ( 2013-01-29 11:10:42 -0500 )edit
Is @hsu just committing to the simulator_gazebo stack for kicks? https://code.ros.org/trac/ros-pkg/changeset/40366
jbohren gravatar imagejbohren ( 2013-03-13 11:19:04 -0500 )edit
@jbohren well, it is fun, you should try it sometimes :) trying to spin up another groovy release with gazebo 1.5. turns out some of these test worlds might end up as gazebo unit tests directly in gazebo.
hsu gravatar imagehsu ( 2013-03-13 12:18:44 -0500 )edit
@hsu (: I might if I still had commit access to ros-pkg. I was actually going to create a branch to add something a couple months ago. Any thoughts on migrating that to git/hg/github/bitbucket?
jbohren gravatar imagejbohren ( 2013-03-13 12:27:04 -0500 )edit
answered 2013-03-29 12:31:57 -0500
hsu gravatar image
@jbohren you already know but I've moved simulator_gazebo to https://bitbucket.org/osrf/simulator_gazebo
@joseescobar60 can you try this on groovy branch? Or file a ticket on bitbucket for fuerte. Be sure to include both terminals where you started gazebo and where the spawn commands were given. Also, if possible, include the shadow hand model that you're using.
Thanks. John
The link to simulator_gazebo is missing an "o"... also This should be more prominently advertized!
SL Remy gravatar imageSL Remy ( 2013-04-16 21:19:16 -0500 )edit
What would you like tested?
SL Remy gravatar imageSL Remy ( 2013-04-17 09:46:35 -0500 )edit
2 followers
Asked: 2012-11-30 04:44:19 -0500
Seen: 1,131 times
Last updated: Mar 29 '13
