output of camera plugin in standalone gazebo
asked 2013-06-24 11:05:23 -0600
Hi all,
Dear Friends, i want to do a simple project and i need to image processing, i should say that i work with standalone version of gazebo (1.8) (without ROS), so, i inserted a camera in gazebo and i get output of it with this command:
> gztopic echo /gazebo/default/camera/link/camera/image
but i can't understand its output:
    time {
  sec: 17
  nsec: 449000000
image {
  width: 5
  height: 2
  pixel_format: 3
  step: 15
  data: "\255\273\336\250\267\333\246\264\332\246\265\332\251\267\333\214\214\214\214\214\214\214\214\214\214\214\214\214\214\214"
any one can explain the output? also i set width = 5 and height=2 in SDF file of camera. i want to know what is the pixel_format and step and order of data ?!
answered 2013-06-25 09:42:11 -0600
SL Remy gravatar image
The data is the raw value of the pixels. There are 30 (5*2 sets of RGB values) in the item. From a brief look at Image.hh, the format 3 is probably RGB_INT8.
The step is how long a row of data is in the image (5 pixels and 3 values for each pixel).
Thank you so much, but my friend i can't understand exactly order of data? based on your explanation the first three number are for first pixel in first line and first column (or in other way the first fifteen number are for first row of image), and data printed row by row? am i right?!
Vahid gravatar imageVahid ( 2013-06-25 10:41:02 -0600 )edit
That's how I interpret the data.
SL Remy gravatar imageSL Remy ( 2013-06-25 13:14:42 -0600 )edit
Thank you so much my friend.
Vahid gravatar imageVahid ( 2013-06-25 14:56:43 -0600 )edit
Asked: 2013-06-24 11:05:23 -0600
Seen: 703 times
Last updated: Jun 25 '13
