my world is changed when i loaded it
asked 2013-07-01 14:56:05 -0500
Vahid gravatar image
updated 2013-07-11 05:52:35 -0500
Hi Dear All,
I create a world in Gazebo (Standalone Version 1.8) and I saved it, but when i load it, my world is changed?! any one know what is my fault?
for example i create this world but when i load it i have this world, I've marked the changed part.
i loaded my world with this command:
>gazebo name_of_saved_world
and i save the world from file menu (save world as).
I've attached a world with a box. test4.sdf
Can you provide a few more details about your problem.
nkoenig gravatar imagenkoenig ( 2013-07-01 17:53:03 -0500 )edit
Yes, I've added detail of my problem to main question, thank you so much for your consideration.
Vahid gravatar imageVahid ( 2013-07-02 00:52:18 -0500 )edit
Can you add some code that shows the before and after differences? It will be hard for us to replicate the error just based on the images you attached. Thanks.
scpeters gravatar imagescpeters ( 2013-07-10 18:47:18 -0500 )edit
Model rotations don't get saved. To replicate: insert a box, rotate it, File -> Save World As. Load the saved world to see the model with zero rpy.
iche033 gravatar imageiche033 ( 2013-07-10 21:26:53 -0500 )edit
Dear Scpeters, There is just one code ( a SDF File), for example i put a box in world and then rotate it and in final i save it, but when i load it, the box is in original form! I've attached this SDF file to main question, you can test it and see the result.
Vahid gravatar imageVahid ( 2013-07-11 05:58:19 -0500 )edit
answered 2013-07-10 18:21:26 -0500
There are currently some problems with saving worlds. I've added yours to the existing ticket on the gazebo issue tracker:
https://bitbucket.org/osrf/gazebo/issue/563/fix-saving-worlds
Thank you so much.
Vahid gravatar imageVahid ( 2013-07-11 06:00:32 -0500 )edit
Asked: 2013-07-01 14:56:05 -0500
Seen: 262 times
Last updated: Jul 11 '13
