Warning [RenderEngine.cc:691] Frame Buffer Objects (FBO) is missing
asked 2013-07-12 22:28:26 -0500
indranilsaha gravatar image
I am running Gazebo using the following command:
gazebo /usr/local/share/gazebo-1.8/worlds/camera.world
And I am getting the following warnings
Gazebo multi-robot simulator, version 1.8.6Copyright (C) 2013 Open Source Robotics Foundation.Released under the Apache 2 License. http://gazebosim.org
Gazebo multi-robot simulator, version 1.8.6 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
Msg Waiting for master.Msg Waiting for master Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 128.32.171.243
Warning [RenderEngine.cc:687] GLSL is missing.Fixed function rendering will be used.
Warning [RenderEngine.cc:691] Frame Buffer Objects (FBO) is missing. Rendering will be disabled.
Error [CameraSensor.cc:91] Unable to create CameraSensor. Rendering is disabled.
Also nothing is being displayed on the screen.
Can anyone help me figure out what I am doing wrong?
Thanks, Indranil
what graphics card do you have and do you have the drivers installed?
iche033 gravatar imageiche033 ( 2013-07-15 13:15:02 -0500 )edit
the command 05:00.0 VGA compatible controller: NVIDIA Corporation G98 [Quadro NVS 420] (rev a1) 09:00.0 VGA compatible controller: NVIDIA Corporation G98 [Quadro NVS 420] (rev a1)
indranilsaha gravatar imageindranilsaha ( 2013-07-15 20:39:07 -0500 )edit
How can I know if I have the drivers installed? uname -a produces the following output: Linux VeriFun 3.2.0-45-generic #70-Ubuntu SMP Wed May 29 20:12:06 UTC 2013 x8664 x8664 x86_64 GNU/Linux
indranilsaha gravatar imageindranilsaha ( 2013-07-15 20:41:20 -0500 )edit
looks like you have a nvidia card, try: dpkg -l | grep nvidia-current and if it says ii at the beginning of the line then it's installed. Otherwise install the driver. Also make sure you have direct rendering: glxinfo | grep render should tell you.
iche033 gravatar imageiche033 ( 2013-07-16 12:28:35 -0500 )edit
Thank you. nvidia-current was not installed and I installed it. But glxinfo | grep render gives the following output:direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose) OpenGL renderer string: Intel HD Graphics 4000 OpenGL Engin. I could not figure out how I can enable direct rendering.
indranilsaha gravatar imageindranilsaha ( 2013-07-16 17:50:21 -0500 )edit
normally it should just load the nvidia module on reboot. Did you reboot your computer after you installed it? nvidia-settings may give some useful info
iche033 gravatar imageiche033 ( 2013-07-16 19:17:03 -0500 )edit
Rebooting the machine did not solve the problem. Still I am getting "direct rendering: No". When I am using nvidia-settings, I am getting "You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run nvidia-xconfig as root), and restart the X server." Is there anything wrong in a configuration file?
indranilsaha gravatar imageindranilsaha ( 2013-07-17 18:58:27 -0500 )edit
glxinfo | grep render gives the following output:direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose) OpenGL renderer string: Intel HD Graphics 4000 OpenGL Engin. I was thinking may be the graphics card is by Intel, not by Nvidia. Is there any command that can be used to confirm the graphics card in the system?
indranilsaha gravatar imageindranilsaha ( 2013-07-18 15:32:53 -0500 )edit
oh I thought you have nvidia card because in the second comment you wrote VGA compatible controller: NVIDIA Corporation G98 [Quadro NVS 420]. Try running lspci -v | grep -i nvidia, or lshw | grep -i nvidia and see if you have an nvidia device
iche033 gravatar imageiche033 ( 2013-07-18 16:44:10 -0500 )edit
Here is the partial output of lspci -v | grep -i nvidia
indranilsaha gravatar imageindranilsaha ( 2013-07-18 18:41:09 -0500 )edit
