Initializing controller failed (RRBOT tutorial)
asked 2013-08-01 15:38:35 -0600
Arn-O gravatar image
Hi folks.
I'm working on the tutorial of Gazebo 1.9 with rrbot and currently facing the following error messages.
From the controller start launch file:
[INFO] [WallTime: 1375388998.774908] [0.000000] Loading controller: joint1_position_controller
[ERROR] [WallTime: 1375389000.170747] [28.387000] Failed to load joint1_position_controller
[INFO] [WallTime: 1375389000.171134] [28.387000] Loading controller: joint2_position_controller
[ERROR] [WallTime: 1375389001.195123] [29.373000] Failed to load joint2_position_controller
And from the Gazebo launch file:
[ERROR] [1375388999.165926429, 27.406000000]: Exception thrown while initializing controller joint1_position_controller.
Could not find resource 'joint1' in 'hardware_interface::EffortJointInterface'.
[ERROR] [1375388999.166263170, 27.406000000]: Initializing controller 'joint1_position_controller' failed
[ERROR] [1375389000.189563304, 28.401000000]: Exception thrown while initializing controller joint2_position_controller.
Could not find resource 'joint2' in 'hardware_interface::EffortJointInterface'.
[ERROR] [1375389000.190056911, 28.404000000]: Initializing controller 'joint2_position_controller' failed
I have followed the tutorial step by step and used the gazeborosdemos package.
Thank for the help.
answered 2013-08-04 02:26:44 -0600
Well, I changed a lot of things, so I'm not sure of what was the root cause.
What I did:
  • install ros-hydro-desktop-full
  • install gazebo, which has removed the previous package, but only the meta package (fixed in the meantime)
  • install ros_control from the source (did not manage to make the deb version work)
  • install roscontroller, controltoolbox and real_time (since again the package were missing or inconsistent in the debs)
And this is now working fine.
I think the debians were just out of date, I just released a update that should be in public with the next Hydro public sync
davetcoleman gravatar imagedavetcoleman ( 2013-08-06 20:27:29 -0600 )edit
Asked: 2013-08-01 15:38:35 -0600
Seen: 1,723 times
Last updated: Aug 04 '13
