floating point exception in gzserver
asked 2013-08-09 21:25:25 -0600
munnveed gravatar image
I am trying to get started with gazebo and I just about finished following the instructions here:
http://gazebosim.org/wiki/1.9/install
I installed using the pre-compiled binaries on Ubuntu 13.04.
I am having trouble starting gzserver however. It crashes with a floating point exception error. Does anyone have an insights? This is the output:
Gazebo multi-robot simulator, version
1.9.0 Copyright (C) 2013 Open Source Robotics Foundation.
Msg Waiting for master
Msg Publicized address: 192.168.1.198
Floating point exception (core dumped)
Could you run it with gdb as well to get more info? It guess it would help figuring out the problem.
AndreiHaidu gravatar imageAndreiHaidu ( 2013-08-10 09:53:59 -0600 )edit
So I'm running it on an Ubuntu 12.04 now, with no problems. I don't have the 13.04 anymore, so I'm can't debug.
munnveed gravatar imagemunnveed ( 2013-08-16 02:10:33 -0600 )edit
I can confirm the bug, I'm running Arch Linux. I have uploaded the gdb in pastebin: http://pastebin.com/YcBPcxK7
chutsu gravatar imagechutsu ( 2013-09-05 08:49:39 -0600 )edit
