Is there a NAO model in Gazebo?
asked 2013-09-26 20:13:38 -0500
Hello Everyone!!
I found model in ROS:
http://wiki.ros.org/nao_description
And videos in Gazebo:
Nao robot in Gazebo with a hierarchical finite state machine.
https://www.youtube.com/watch?v=3zhxi...
Prova del modello del NAO in ROS usando Joint State Publisher e Gazebo
https://www.youtube.com/watch?v=lZv3M...
Simulazione della camminata del NAO in Gazebo
https://www.youtube.com/watch?v=pLk4N...
Or How could load NAO model using ROS in Gazebo?
A lot of thanks!!!
vncntmh gravatar imagevncntmh ( 2013-09-29 11:51:13 -0500 )edit
answered 2013-10-01 13:20:59 -0500
nkoenig gravatar image
You can start by using the Nao urdf (which Gazebo can/should read).
It might be easiest to look at example. We used URDF of the Atlas robot for both Gazebo and ROS.
Here is the Atlas description. In this example, the Atlas description is also a Gazebo Model.
Here is an example launch file that will spawn Atlas.
Asked: 2013-09-26 20:13:38 -0500
Seen: 6,189 times
Last updated: Oct 01 '13
