Make Gazebo (ODE) deterministic or reset random number generator?
asked 2013-10-01 15:48:44 -0500
Nick Eckenstein gravatar image
I am running a lot(~1000s) of quick simulations one at a time and doing a World::Reset() between each one. Is there some way to ensure that the random numbers generated by Gazebo are the same after each World::Reset()? Can I reset the RNG? If I just set the seed again, will that restart the RNG?
Right now, I have a small (~1 in 1000) chance of the RNG causing the result of my simulation to change - I'd like to fix the random numbers generated so that I can observe the behavior causing my simulation to fail. Thanks.
2
answered 2013-10-06 11:58:46 -0500
nkoenig gravatar image
This may the tutorial you are looking for: http://gazebosim.org/wiki/Tutorials/1...
Thanks Nate! I've set the seed already. Unfortunately when I reset the world using World::Reset(), the RNG doesn't seem to reset and as a result I can run the same simulation over again and get different results. I would like to be able to reproduce my results and still automate the process of running multiple trials. How do you recommend that I do this?
Nick Eckenstein gravatar imageNick Eckenstein ( 2013-10-07 09:51:02 -0500 )edit
I've made an [issue](https://bitbucket.org/osrf/gazebo/issue/876/reset-random-number-generator) out of this. Please track updates there.
nkoenig gravatar imagenkoenig ( 2013-10-07 11:29:36 -0500 )edit
Great, thanks!
Nick Eckenstein gravatar imageNick Eckenstein ( 2013-10-07 15:37:36 -0500 )edit
Asked: 2013-10-01 15:48:44 -0500
Seen: 517 times
Last updated: Oct 06 '13
