No gazebo-ros package after update?
asked 2013-10-10 08:58:59 -0600
RafBerkvens gravatar image
After the recent 2.0.0 Gazebo update, I can no longer run gazebo_ros. It has been deinstalled during the update. When trying to install gazebo-ros-pkgs, I get the following output:
The following packages have unmet dependencies:
 ros-hydro-gazebo-ros-control : Depends: ros-hydro-gazebo-ros but it is not going to be installed
 ros-hydro-gazebo-ros-pkgs : Depends: ros-hydro-gazebo-plugins but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
When trying to install the mentioned ros-hydro-gazebo-ros, this is the output:
 ros-hydro-gazebo-ros : Depends: gazebo but it is not going to be installed
Yet, gazebo is installed and can be run.
Is there something broken in the repository?
i have this problem also!
Vahid gravatar imageVahid ( 2013-10-22 09:27:00 -0600 )edit
The repository was somewhat broken during some hours, it should be fixed now. Try to uninstall gazebo package and read the instructions to use Gazebo with ROS
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2013-10-22 17:21:12 -0600 )edit
answered 2013-10-10 10:24:51 -0600
nkoenig gravatar image
This issue is tracking the problem. The problem should be resolved very soon.
As Nate said, it should happen very soon, but some more information and workaround are covered in this answer.
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2013-10-10 11:57:37 -0600 )edit
Thanks for both the reply and the comment. I'm now waiting for the actual update to happen.
RafBerkvens gravatar imageRafBerkvens ( 2013-10-11 01:36:41 -0600 )edit
For problems related to Gazebo and ROS, be sure to read the Gazebo/ROS integration document
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2013-10-22 07:49:01 -0600 )edit
Asked: 2013-10-10 08:58:59 -0600
Seen: 897 times
Last updated: May 02 '14
