Launching empty world segfault in ROS
asked 2012-10-05 14:20:52 -0500
falcon1 gravatar image
I am on an Ubuntu 12.04 LTS 64bit and running off of an Intel 915 chipset. My current gazebo distribution is 1.6.16
Running empty_world.launch would segfault, so I ran debug.launch and this is the result:
roslaunch gazebo_worlds debug.launch
... logging to /home/falkor/.ros/log/5f384930-0f1f-11e2-a67f-5891cf52dcee/roslaunch-pc-16477.log
Press Ctrl-C to interrupt
started roslaunch server http://127.0.0.1:33650/
SUMMARY
PARAMETERS * /rosdistro * /rosversion * /usesimtime
NODES / gazebo (gazebo/debug) gazebo_gui (gazebo/gui)
auto-starting new master Exception AttributeError: AttributeError("'DummyThread' object has no attribute 'Thread_block'",) in <module 'threading'="" from="" '="" usr="" lib="" python2.7="" threading.pyc'=""> ignored process[master]: started with pid [16493] ROSMASTER_URI=http://127.0.0.1:11311
setting /run_id to 5f384930-0f1f-11e2-a67f-5891cf52dcee Exception AttributeError: AttributeError("'DummyThread' object has no attribute 'Threadblock'",) in <module 'threading'="" from="" '="" usr="" lib="" python2.7="" threading.pyc'=""> ignored process[rosout-1]: started with pid [16506] started core service [/rosout] Exception AttributeError: AttributeError("'DummyThread' object has no attribute 'Threadblock'",) in <module 'threading'="" from="" '="" usr="" lib="" python2.7="" threading.pyc'=""> ignored process[gazebo-2]: started with pid [16520] Exception AttributeError: AttributeError("'DummyThread' object has no attribute 'Thread_block'",) in <module 'threading'="" from="" '="" usr="" lib="" python2.7="" threading.pyc'=""> ignored process[gazebogui-3]: started with pid [16530] GNU gdb (Ubuntu/Linaro 7.4-2012.04-0ubuntu2) 7.4-2012.04 Copyright (C) 2012 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x8664-linux-gnu". For bug reporting instructions, please see: http://bugs.launchpad.net/gdb-linaro/... Reading symbols from /opt/ros/fuerte/stacks/simulatorgazebo/gazebo/gazebo/bin/gzserver...Gazebo multi-robot simulator, version 1.0.2 Copyright (C) 2011 Nate Koenig, John Hsu, Andrew Howard, and contributors. Released under the Apache 2 License. http://gazebosim.org
(no debugging symbols found)...done. [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [Thread debugging using libthreaddb enabled] Using host libthreaddb library "/lib/x8664-linux-gnu/libthreaddb.so.1". [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] Gazebo multi-robot simulator, version 1.0.2 Copyright (C) 2011 Nate Koenig, John Hsu, Andrew Howard, and contributors. Released under the Apache 2 License. http://gazebosim.org
[tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device] [tcsetpgrp failed in terminalinferior ...
(more)
Do you also get a segfault when running stageros?
SL Remy gravatar imageSL Remy ( 2012-10-21 20:53:45 -0500 )edit
Can you post a backtrace from where the segfault occurs?
gerkey gravatar imagegerkey ( 2013-01-11 19:35:49 -0500 )edit
answered 2012-10-18 11:45:19 -0500
nkoenig gravatar image
This error: [tcsetpgrp failed in terminalinferior: Inappropriate ioctl for device]
Looks like a system level problem. As in you have a fundamental issue with hardware or software outside the scope of gazebo.
It looks like the tcsetpgrp error is coming from gdb, something to do with how it's trying to manipulate the console. I don't think that it's related to the segfault.
gerkey gravatar imagegerkey ( 2013-01-11 19:35:28 -0500 )edit
Asked: 2012-10-05 14:20:52 -0500
Seen: 1,667 times
Last updated: Oct 18 '12
