Issues with the physical simulation of gazebo
asked 2013-10-23 11:59:23 -0500
mikegao88 gravatar image
Hello! I encounter an issue regarding the physical simulation of gazebo, which is that the object in the simulated world keeps rolling over forever and just does not stop. I have uploaded related files (including the model file and world file) to help solve the problem:
https://drive.google.com/folderview?id=0B49go8f2Nr2gZzY4R3VnNGJMNTQ&usp=sharing
Although I set the friction parameters for both the world and the object, the problem still exists. When I use box to approximate the object model, the object shakes forever and does not stop.
I use gazebo 1.9.1 in ubuntu precise 32bit. Thanks for any help!
No one helps with this?
mikegao88 gravatar imagemikegao88 ( 2013-10-25 09:02:48 -0500 )edit
answered 2013-10-25 12:43:27 -0500
nkoenig gravatar image
updated 2013-10-25 13:01:23 -0500
When objects jitter, it's usually because the inertia values are bad or the physics timestep size is too large.
You can cause a sphere to slowly stop rolling by applying a velocity decay value.
I modified your test.world a bit, and the box seems stable:
<sdf version='1.4'>
  <world name='default'>
      <uri>model://sun</uri>
    <physics type='ode'>
      <max_step_size>0.001</max_step_size>
      <real_time_update_rate>1000</real_time_update_rate>
      <gravity>0 0 -9.8</gravity>
    </physics>
    <model name='batterie'>
      <pose>5.486 2.3746 0.5 0 -0 0</pose>
      <link name='link'>
            <ixx>1</ixx> <ixy>0</ixy> <ixz>0</ixz>
            <iyy>1</iyy> <iyz>0</iyz>
            <izz>1</izz>
          <mass>1</mass>
        <collision name='collision'>
              <size>0.15 0.3 0.075</size>
        <visual name='visual'>
  </world>
Asked: 2013-10-23 11:59:23 -0500
Seen: 1,184 times
Last updated: Oct 25 '13
