Error [Plugin.hh:127] undefined symbol
asked 2013-11-04 08:25:29 -0600
Eisenhorn gravatar image
updated 2013-11-05 10:08:05 -0600
Before I ask my question here my system specs:
  • 3.8.0-32-generic #47~precise1-Ubuntu SMP Wed Oct 2 16:19:35 UTC 2013 x8664 x8664 x86_64 GNU/Linux
  • g++ (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3
  • ldd (Ubuntu EGLIBC 2.15-0ubuntu10.5) 2.15
  • ROS Fuerte
  • Gazebo 1.9 and Gazebo 1.8.6
Me and a college are working on a gazebo Plugin.
When my college compiles the library, i can use it without any problems at runtime with the robot model. Yet when I compile the very same library i get an undefined symbol error:
Error [Plugin.hh:127] Failed to load plugin /home/user/eclipse_ws/plugin_cmds/libtaurob_plugin_ros.so: /home/user/eclipse_ws/plugin_cmds/libtaurob_plugin_ros.so: undefined symbol: _ZN3ros7console13g_initializedE
My collegue is using gazebo 1.8.6. I have tried and failed using gazebo 1.8.6 and 1.9 (using the corresponing headers and gazebo simulator versions).
It looks like a name mangeling problem. But maybe somehone has encountered a similar problem?
Doing ldd libtaurobpluginros.so gives this as a result. At least every required library is found.
    linux-vdso.so.1 =>  (0x00007fffc0bf2000)
libgazebo_physics.so.1 => /usr/lib/libgazebo_physics.so.1 (0x00007f7dd5c26000)
libgazebo_sensors.so.1 => /usr/lib/libgazebo_sensors.so.1 (0x00007f7dd5991000)
libgazebo_math.so.1 => /usr/lib/libgazebo_math.so.1 (0x00007f7dd5759000)
libgazebo_common.so.1 => /usr/lib/libgazebo_common.so.1 (0x00007f7dd54a9000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f7dd51a9000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7dd4eac000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f7dd4c96000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7dd48d6000)
libgazebo_util.so.1 => /usr/lib/libgazebo_util.so.1 (0x00007f7dd4658000)
libgazebo_physics_ode.so.1 => /usr/lib/libgazebo_physics_ode.so.1 (0x00007f7dd43bc000)
libgazebo_transport.so.1 => /usr/lib/libgazebo_transport.so.1 (0x00007f7dd4128000)
libgazebo_msgs.so.1 => /usr/lib/libgazebo_msgs.so.1 (0x00007f7dd3dbf000)
libprotobuf.so.7 => /usr/lib/libprotobuf.so.7 (0x00007f7dd3ad0000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f7dd38cc000)
libsdformat.so.1 => /usr/lib/libsdformat.so.1 (0x00007f7dd3607000)
libboost_thread.so.1.46.1 => /usr/lib/libboost_thread.so.1.46.1 (0x00007f7dd33ee000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7dd31d1000)
libboost_system.so.1.46.1 => /usr/lib/libboost_system.so.1.46.1 (0x00007f7dd2fcc000)
libboost_regex.so.1.46.1 => /usr/lib/libboost_regex.so.1.46.1 (0x00007f7dd2cca000)
libgazebo_rendering.so.1 => /usr/lib/libgazebo_rendering.so.1 (0x00007f7dd2917000)
libboost_filesystem.so.1.46.1 => /usr/lib/libboost_filesystem.so.1.46.1 (0x00007f7dd26f8000)
libboost_iostreams.so.1.46.1 => /usr/lib/libboost_iostreams.so.1.46.1 (0x00007f7dd24df000)
libfreeimage.so.3 => /usr/lib/libfreeimage.so.3 (0x00007f7dd21e5000)
libtinyxml.so.2.6.2 => /usr/lib/libtinyxml.so.2.6.2 (0x00007f7dd1fd0000)
libcurl.so.4 => /usr/lib/x86_64-linux-gnu/libcurl.so.4 (0x00007f7dd1d73000)
libtar.so.0 => /usr/lib/libtar.so.0 (0x00007f7dd1b66000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f7dd195e000)
/lib64/ld-linux-x86-64.so.2 (0x00007f7dd621b000)
libgazebo_ode.so.1 => /usr/lib/libgazebo_ode.so.1 (0x00007f7dd1694000)
libtbb.so.2 => /usr/lib/libtbb.so.2 (0x00007f7dd1467000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f7dd124f000)
libicuuc.so.48 => /usr/lib/libicuuc.so.48 (0x00007f7dd0ee5000 ...
(more)
answered 2013-11-04 18:27:10 -0600
scpeters gravatar image
A clue to the problem is in the name of the undefined symbol: _ZN3ros7console13g_initializedE. It appears that you are trying to call ros functions (specifically ros console functions), but you have not linked your library with the ros libraries. Can you try linking with the ROS libraries that you use?
Hi! Thanks for your answer. I have updated my original post with more information, including the CMakeList.txt. The CMakeList.txt is based upon the tutorial from http://gazebosim.org/wiki/Tutorials#Plugins. I am not sure where the Variables such as roscppLIBRARYDIRS are specified. Also I cant run the rosbuildinit() script, as the plugin is no package. Is it sufficient to add this line in order to link the libraries targetlinklibraries(taurobpluginros ${GAZEBOLIBRARIES} ... BR
Eisenhorn gravatar imageEisenhorn ( 2013-11-05 10:13:49 -0600 )edit
targetlinklibraries(taurobpluginros ${GAZEBOLIBRARIES} ${roscppLIBRARIES} ${rosconsole_LIBRARIES})I tried that but nothing changed.
Eisenhorn gravatar imageEisenhorn ( 2013-11-05 10:14:10 -0600 )edit
You commented out the #find_package(roscpp std_msgs genmsg), so I don't think the variables like roscpp_INCLUDE_DIRS will exist. You can test by printing them out `message(STATUS "roscppINCLUDEDIRS ${roscppINCLUDEDIRS}"). Since this is starting to become a question about ROS, you may consider posting at answers.ros.org as well, since I'm not currently using fuerte.
scpeters gravatar imagescpeters ( 2013-11-06 12:29:39 -0600 )edit
Ahhhhhhhh thank you so much. I just included the line find_package(roscpp). Now ldd links to the corresponding library taurob.llibrosconsole.so => /opt/ros/fuerte/lib/librosconsole.so (0x00007ff940ff0000)
Eisenhorn gravatar imageEisenhorn ( 2013-11-12 05:01:11 -0600 )edit
Asked: 2013-11-04 08:25:29 -0600
Seen: 2,046 times
Last updated: Nov 05 '13
