Problem when install drcsim
asked 2013-12-10 21:41:20 -0600
weiweihuang gravatar image
I meet a problem when install drcsim. I have installed groovy. After that I installed gazebo stuffs.
sudo apt-get update
sudo apt-get install gazebo osrf-common sandia-hand
sudo apt-get install drcsim
Here is the error:
The following packages have unmet dependencies:
drcsim : Depends: gazebo (>= 1.4.0) but it is not going to be installed
      Depends: osrf-common but it is not going to be installed
      Depends: sandia-hand but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Any clue for the error? I did not get any error when install gazebo, osrf-common and sandia-hand.
Thank you very much.
I could not reproduce this problem, the transition from uninstall gazebo and install gazebo-current with the rest of drcsim dependencies is automatic in my system. What happen if you run apt-get install -f ?
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2013-12-12 18:49:55 -0600 )edit
Thank you. I guess it is because my ubuntu version. I reinstall my ubuntu with 64bit one. I do not have this problem.
weiweihuang gravatar imageweiweihuang ( 2014-01-03 22:31:06 -0600 )edit
answered 2013-12-12 18:24:06 -0600
scpeters gravatar image
There are currently two gazebo packages (gazebo and gazebo-current). I believe drcsim depends on gazebo-current. Can you uninstall gazebo and just try to install drcsim to see what it wants to be installed?
sudo apt-get remove gazebo
Asked: 2013-12-10 21:41:20 -0600
Seen: 240 times
Last updated: Dec 12 '13
