how to modify the pose of a robot by msgs?
asked 2014-01-15 20:33:29 -0600
Sam gravatar image
updated 2014-01-15 20:42:50 -0600
The name of a existing model is "ball". I use "this->node->Advertise<msgs::pose>(std::string("~/") + ball + "/pose");" to create a transport::PublisherPtr, but it doesn't work. How to create a publisherPtr? thanks.
Can you provide more information about how it fails? Does it fail to compile? Seg fault or the message is not published? Please also include a code example.
isura gravatar imageisura ( 2014-01-16 11:29:37 -0600 )edit
answered 2014-01-16 17:35:23 -0600
nkoenig gravatar image
A model does not automatically create a topic through which you can modify it's pose.
There is a general purpose topic called ~/model/modify which receives a model message
You can use the topic and message like this:
transport::PublisherPtr modelPub = this->node->Advertise<msgs::Model>("~/model/modify");
msgs::Model msg;
msg.set_name("ball");
msgs::Set(msg.mutable_pose(), math::Pose(0, 0, 10, 0, 0, 0));
modelPub->Publish(msg);
thanks a lot!
Sam gravatar imageSam ( 2014-01-16 19:20:02 -0600 )edit
I am trying to do the same thing but I'm having some issues. I started from the following example (https://bitbucket.org/osrf/gazebo/src/e18491b2ff1a/examples/stand_alone/publisher/?at=default) and modified it to use the above code. The result is that the model jumps around in Gazebo, always returning to it's original position, in a very discontinuous way. You can see my code here: http://pastebin.com/BG1HLhDn
What is the problem?
NickDP gravatar imageNickDP ( 2014-09-10 18:27:28 -0600 )edit
2 followers
Asked: 2014-01-15 20:33:29 -0600
Seen: 1,186 times
Last updated: Jan 16 '14
