Problem when to try to load to Atlas using Gazebo 2.0
asked 2014-02-05 19:07:07 -0500
updated 2014-02-05 19:09:04 -0500
When to try to insert Atlas from Gazebo get this error:
Error [parser_urdf.cc:2608] Unable to call parseURDF on robot model
Error [parser.cc:273] parse as old deprecated model file failed.
Error [ModelMaker.cc:126] Unable to load file[/opt/ros/groovy/share/drcsim_model_resources/gazebo_models/environments/atlas_description/dummy.urdf]
And have problems when try to load from terminal using:
VRC_CHEATS_ENABLED=1 roslaunch atlas_utils atlas.launch
getting this error:
 [atlas.launch] is neither a launch file in package [atlas_utils] nor is [atlas_utils] a launch file name
answered 2014-02-05 19:22:40 -0500
Jose Luis Rivero gravatar image
The roslaunch command changed in the latest versions and now is:
roslaunch drcsim_gazebo atlas.launch
Probably you have read an outdated documentation, could you please point me to it? Thanks.
vncntmh gravatar imagevncntmh ( 2014-02-06 16:08:08 -0500 )edit
You are right, they should be updated to version 3.3.1, thanks for the information.
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2014-02-06 16:17:38 -0500 )edit
asomerville gravatar imageasomerville ( 2014-05-06 12:02:26 -0500 )edit
Thanks very much Andrew!
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2014-05-08 19:29:51 -0500 )edit
Asked: 2014-02-05 19:07:07 -0500
Seen: 272 times
Last updated: Feb 05 '14
