What is a simple way to run Gazebo with no graphics?
asked 2012-12-19 22:31:34 -0600
cga gravatar image
I want to run Gazebo without the X11 window it creates.
If I am simulating vision, I still need to run OGRE to generate images.
Thanks, Chris
answered 2012-12-19 23:39:56 -0600
scpeters gravatar image
We plan on adding a tutorial for this, but in the meantime, here's a quick explanation. When you launch gazebo, there are two programs that are run: gzserver and gzclient. The program gzserver does all the simulation, even rendering for camera simulation. The interactive window is opened by gzclient.
To open a specific world, type gzserver specific.world.
I'm still a couple of versions back, but you'd also need to make sure that you've set the DISPLAY environment appropriately if you're not directly using the console..
SL Remy gravatar imageSL Remy ( 2012-12-21 00:47:29 -0600 )edit
answered 2012-12-26 18:52:37 -0600
PMilani gravatar image
If you're running the ROS version of Gazebo and using launch files, then I suggest modifying your launch file and commenting out the line regarding the Gazebo gui. Then only the gzserver part of gazebo will launch
This worked for me. Thanks. Funny that a tutorial was in the planning back in 2012 and this question is still the first to appear in a simple google search
shaihi gravatar imageshaihi ( 2018-01-11 15:46:24 -0600 )edit
Asked: 2012-12-19 22:31:34 -0600
Seen: 3,064 times
Last updated: Dec 26 '12
