Error in Setup gazebo plugin paths - GAZEBO_PLUGIN_PATH
asked 2014-03-12 15:01:44 -0500
Hi, I am trying to add a controller to my robot, (using plugin). So I am going to follow the tutorials Mobile Base Control and Plugin Hello World. But I have three problem: 1 - /grad/hadi.kazemi/myplugin/myplugin.cc:2:21: fatal error: gazebo.hh: No such file or directory so I add a /gazebo/ to all include lines and the error vanished.
2 - error: ‘ConnectWorldUpdateStart’ is not a member of ‘gazebo::event::Events’ when I try to make, so I delete this line (this line was in the first tutorial).
3 - after removing the make worked well but when I try to run this command: export GAZEBOPLUGINPATH=pwd:$GAZEBOPLUGINPATH or export GAZEBOPLUGINPATH=${GAZEBOPLUGINPATH}:~/myplugin/build/ it gave me this error: GAZEBOPLUGINPATH: Undefined variable. and so when I add my model to the world (using insert) I have: Error [Plugin.hh:152] Failed to load plugin libmyplugin.so: libmy_plugin.so: cannot open shared object file: No such file or directory
how can I handle these errors?
did you source your bashrc after setting the plugin path? you can verify it by running $ echo $GAZEBO_PLUGIN_PATH, and see if the path where the plugin .so is included
AndreiHaidu gravatar imageAndreiHaidu ( 2014-03-12 16:46:53 -0500 )edit
I did not install gazebo in the computer by myself. I am a PhD student and the university tech group installed it for me. I have not a root access and I don't know what is bachrc? I did your command : echo $GAZEBOPLUGINPATH and the same error: GAZEBOPLUGINPATH: Undefined variable.
Hadi Kazemi gravatar imageHadi Kazemi ( 2014-03-13 16:07:26 -0500 )edit
answered 2014-03-18 10:52:48 -0500
I solve my problem by adding "setenv GAZEBO_PLUGIN_PATH ~/my_plugin/build" to .cshrc
Asked: 2014-03-12 15:01:44 -0500
Seen: 1,703 times
Last updated: Mar 25 '14
