Tutorial ROS enabled model plugin?
asked 2013-01-07 14:38:07 -0600
raulpl25 gravatar image
updated 2013-01-07 21:44:38 -0600
I'm following the tutorial "Tutorials/1.2/ros enabled model plugin" in order to enable the plugins with ROS, but I have problems when I try to build the code. The CMake throw the following error:
-- The C compiler identification is GNU 4.7.2
-- The CXX compiler identification is GNU 4.7.2
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.26")
-- checking for module 'gazebo' -- package 'gazebo' not found
CMake Error at /usr/share/cmake-2.8/Modules/FindPkgConfig.cmake:279 (message): A required package was not found
Call Stack (most recent call first): /usr/share/cmake-2.8/Modules/FindPkgConfig.cmake:333 (pkgcheckmodulesinternal) CMakeLists.txt:5 (pkgcheckmodules)
Cached location of rospack is invalid; searching for rospack... -- Configuring incomplete, errors occurred!
I'm quite new using CMake and the sintax is too complex for me. I don't know why is not finding gazebo package. I'm using ROS Groovy and Ubuntu 12.10. PD. Sorry I don't know how to give the format to my text.
Thanks in advance.
answered 2013-01-07 23:09:23 -0600
gerkey gravatar image
It looks like you don't have Gazebo installed. We're only making binary packages for Ubuntu 12.04 at the moment, so you'll need to build from source.
Asked: 2013-01-07 14:38:07 -0600
Seen: 400 times
Last updated: Jan 07 '13
