How to Modify a Running Gazebo Simulation?
asked 2014-05-21 14:46:22 -0600
Hi all,
So I am using roslaunch command to simulate a simple Gazebo world file which contains some cubic obstacles. I have a question which I have not been able find any solution for: Once the simulation is up and running, can I add any objects to Gazebo simulation without having to use the graphical user interface? I am using ROS Hydro and Gazebo-1.9.
I would appreciate any kind of help.
Cheers,
Ali
Could you please update the answer and include which version of gazebo are you using?
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2014-05-21 17:18:45 -0600 )edit
Sure, it is ROS Hydro and Gazebo -1.9
ali_mohandes gravatar imageali_mohandes ( 2014-05-21 17:25:18 -0600 )edit
answered 2014-05-21 18:02:47 -0600
There are at least two ways of doing this:
  1. From the command line: using the gzfactory tool (look at the spawn parameter). The user guide described it perfectly.
  2. Programmatically: using a world plugin as described in the corresponding tutorial
Hope it helps.
Thanks a lot. I used gzfactory and it worked. I appreciate your help.
ali_mohandes gravatar imageali_mohandes ( 2014-05-21 22:36:39 -0600 )edit
Asked: 2014-05-21 14:46:22 -0600
Seen: 125 times
Last updated: May 21 '14
