Error building gazebo ros Packages 1.9 from source in Groovy
asked 2014-06-24 04:45:51 -0600
elias gravatar image
updated 2014-06-25 19:43:08 -0600
scpeters gravatar image
On the way to control a PR2 Robot with MoveIt! in Gazebo im following this guide. Due to various reasons Ubuntu Precise with Groovy seems to be the right match for this mission.
In point 6 (Installing GazeboRosPackages) it is recommended to install the Gazebo ros packages. I followed the guide up to 7.2.3 building the gazeborospkgs for Groovy from source as there is no precompiled package for Groovy.
Catkin_make'ing I ran in a couple of issues of missing packages I was able to solve by myself. Unfortunately I now got stuck and don't know where to find a solution. To be honest, I don't understand the cause of the error.
Here is the command line output below. I verified all the mentioned .so-files are present where they belong. Any help is highly appreciated. Thanks!
`elias@Precise-Zeus:~/catkin_ws$ catkin\_make
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins
In file included from /home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins
src/gazebo_ros_hand_of_god.cpp:43:0:
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/include/gazebo_plugins/gazebo_ros_hand_of_god.h:60:30: error: ‘tf2_ros’ was not declared in this scope
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/include/gazebo_plugins/gazebo_ros_hand_of_god.h:60:45: error: template argument 1 is invalid
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/include/gazebo_plugins/gazebo_ros_hand_of_god.h:61:30: error: ‘tf2_ros’ was not declared in this scope
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/include/gazebo_plugins/gazebo_ros_hand_of_god.h:61:56: error: template argument 1 is invalid
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/include/gazebo_plugins/gazebo_ros_hand_of_god.h:62:30: error: ‘tf2_ros’ was not declared in this scope
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/include/gazebo_plugins/gazebo_ros_hand_of_god.h:62:59: error: template argument 1 is invalid
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp: In member function ‘virtual void gazebo::GazeboRosHandOfGod::Load(gazebo::physics::ModelPtr, sdf::ElementPtr)’:
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp:123:16: error: request for member ‘reset’ in ‘((gazebo::GazeboRosHandOfGod*)this)->gazebo::GazeboRosHandOfGod::tf_buffer_’, which is of non-class type ‘int’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp:123:26: error: expected type-specifier before ‘tf2_ros’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp:123:26: error: expected ‘)’ before ‘tf2_ros’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp:124:18: error: request for member ‘reset’ in ‘((gazebo::GazeboRosHandOfGod*)this)->gazebo::GazeboRosHandOfGod::tf_listener_’, which is of non-class type ‘int’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp:124:28: error: expected type-specifier before ‘tf2_ros’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp:124:28: error: expected ‘)’ before ‘tf2_ros’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp:125:21: error: request for member ‘reset’ in ‘((gazebo::GazeboRosHandOfGod*)this)->gazebo::GazeboRosHandOfGod::tf_broadcaster_’, which is of non-class type ‘int’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp:125:31: error: expected type-specifier before ‘tf2_ros’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp:125:31: error: expected ‘)’ before ‘tf2_ros’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_hand_of_god.cpp: In member function ‘virtual void gazebo::GazeboRosHandOfGod ...
(more)
answered 2014-06-26 10:03:57 -0600
which branch are you using? you should make shure that the branch cloned from github is groovy-devel! This should be the branch for groovy and it does not contain the plugin that throws the errors.
So when cloning the repos from github try to add -b groovy-devel
This might fix your problem...
I think the seperation of hydro-devel and groovy-devel branches started after this tutorial was written...
Thanks, that was very useful, now catkinmake reaches [100%] Built target gazeboros_bumper
elias gravatar imageelias ( 2014-07-01 04:10:14 -0600 )edit
answered 2014-12-18 13:46:25 -0600
RoboC gravatar image
I am experiencing the problem mentioned by elias
/home/a9658007/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_openni_kinect.cpp: In member function ‘bool
gazebo::GazeboRosOpenniKinect::FillPointCloudHelper(sensor_msgs::PointCloud2&, uint32_t, uint32_t, uint32_t, void*)’:
/home/a9658007/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_openni_kinect.cpp:376:3: error: ‘toROSMsg’ is not a member of ‘pcl’
make[2]: *** [gazebo_ros_pkgs/gazebo_plugins/CMakeFiles/gazebo_ros_openni_kinect.dir/src/gazebo_ros_openni_kinect.cpp.o] Error 1
make[1]: *** [gazebo_ros_pkgs/gazebo_plugins/CMakeFiles/gazebo_ros_openni_kinect.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
Linking CXX shared library /home/a9658007/catkin_ws/devel/lib/libgazebo_ros_p3d.so
[ 10%] Built target gazebo_ros_p3d
make: *** [all] Error 2
make: INTERNAL: Exiting with 5 jobserver tokens available; should be 4!
The tutorial mentioned in the question has been moved to http://gazebosim.org/tutorials?tut=rosinstalling&ver=1.9%2B&cat=connectros.
I changed the cloning from -b hydro-devel to -b groovy-devel and am still facing the same problem. Any other suggestions?
answered 2014-07-01 04:21:12 -0600
Even progress is shown I still have some problems:
I was able to clone
ros-simulation/gazebo_ros_pkgs.git
ros-controls/ros_control.git
ros-controls/ros_controllers.git
from the groovy-devel branch.
Unfortunately
ros-controls/control_toolbox.git
ros-controls/realtime_tools.git
are not available in the devel branch and so I cloned it the ordinary way.
As mentioned above, catkin_make reaches now 98% but there seems some problem in the point cloud and camera package:
home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_openni_kinect.cpp:376:3: error: ‘toROSMsg’ is not a member of ‘pcl’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_depth_camera.cpp:277:7: error: ‘toROSMsg’ is not a member of ‘pcl’
/home/elias/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_depth_camera.cpp:437:3: error: ‘toROSMsg’ is not a member of ‘pcl’
I googled the problem but couldn't find an useful solution.
Thanks for your help!
Asked: 2014-06-24 04:45:51 -0600
Seen: 591 times
Last updated: Dec 18 '14
