3
Increase Ground Plane Grid Size
asked 2014-07-22 12:24:45 -0600
K. Zeng gravatar image
Hello everyone, I know that you can adjust the size of the ground plane itself, but is there a way to change the size of the gridded area so it's bigger than 20x20? Thanks.
3
answered 2014-07-22 19:38:18 -0600
scpeters gravatar image
I know that the plane geometry tag has a size parameter (see ground_plane model), but it's actually ignored for physics purposes in ODE and is actually an infinite ground plane. The size is used for the visual, which can be seen when you zoom out.
Regarding the grid, that is not a property of the ground plane, but actually a rendering property of the scene. The following tag can be used to disable the grid: <grid>false</grid> (see blank.world) or it can be toggled from the View -> Grid menu.
The size of the grid is currently hard-coded in gazebo::rendering::Scene::SetGrid.
Thank you very much for the answer! Is there a way to access SetGrid.cc so I can change the grid size?? I tried to find a copy of that code on my harddrive, but all I found was SetGrid.hh, which appears to only list the functions, not the functions themselves?
K. Zeng gravatar imageK. Zeng ( 2014-07-23 13:01:33 -0600 )edit
In my application I replaced planes with boxes, with their width = 0.01. I don't know if that's appropriate but seems to be working fine for my purpose (I just needed stairs).
IsaacS gravatar imageIsaacS ( 2015-06-22 05:15:11 -0600 )edit
Asked: 2014-07-22 12:24:45 -0600
Seen: 5,086 times
Last updated: Jul 22 '14
