Fatal error: pcl/conversions.h: No such file or directory.
asked 2014-07-23 03:14:34 -0600
Moda gravatar image
updated 2014-07-23 03:42:33 -0600
I'm using groovy (Ubuntu 12.04). When I do catkin-make I got this error. However the file is in the folder pcl/src/conversions.h
This is my CMakeLists file :
cmake_minimum_required(VERSION 2.8.3)
project(costmap_2d)
find_package(catkin REQUIRED COMPONENTS
  dynamic_reconfigure
  eigen
  geometry_msgs
  laser_geometry
  map_server
  map_msgs
  nav_msgs
  pcl
  pcl_conversions
  pcl_msgs
  pcl_ros
  rosbag
  rosconsole
  roscpp
  sensor_msgs
  std_msgs
  tf
  visualization_msgs
  voxel_grid
  message_generation
find_package(PCL REQUIRED)
find_package(Eigen REQUIRED)
find_package(Boost REQUIRED COMPONENTS system thread)
include_directories(
    include
    ${catkin_INCLUDE_DIRS}
    ${EIGEN_INCLUDE_DIRS}
    ${PCL_INCLUDE_DIRS}
    ${Boost_INCLUDE_DIRS}
add_definitions(${EIGEN_DEFINITIONS})
add_message_files(
    DIRECTORY msg
    FILES
    VoxelGrid.msg
generate_messages(
    DEPENDENCIES
        std_msgs
        geometry_msgs
    map_msgs
# dynamic reconfigure
generate_dynamic_reconfigure_options(
  cfg/Costmap2D.cfg
  cfg/ObstaclePlugin.cfg
  cfg/GenericPlugin.cfg
  cfg/InflationPlugin.cfg
  cfg/VoxelPlugin.cfg
catkin_package(
    INCLUDE_DIRS
        include
        ${PCL_INCLUDE_DIRS}
    LIBRARIES costmap_2d
    CATKIN_DEPENDS
        dynamic_reconfigure
        geometry_msgs
        laser_geometry
        nav_msgs
        pcl_ros
        roscpp
        sensor_msgs
        std_msgs
        tf
        voxel_grid
    DEPENDS
        PCL
        Eigen
        Boost
add_library(costmap_2d
  src/array_parser.cpp
  src/costmap_2d.cpp
  src/observation_buffer.cpp
  src/layer.cpp
  src/layered_costmap.cpp
  src/costmap_2d_ros.cpp
  src/costmap_2d_publisher.cpp
  src/costmap_math.cpp
  src/footprint.cpp
  src/costmap_layer.cpp
add_dependencies(costmap_2d geometry_msgs_gencpp)
target_link_libraries(costmap_2d
  ${PCL_LIBRARIES}
  ${Boost_LIBRARIES}
  ${catkin_LIBRARIES}
add_library(layers
  plugins/footprint_layer.cpp
  plugins/inflation_layer.cpp
  plugins/obstacle_layer.cpp
  plugins/static_layer.cpp
  plugins/voxel_layer.cpp
target_link_libraries(layers
  costmap_2d
add_dependencies(costmap_2d costmap_2d_gencfg)
add_dependencies(layers costmap_2d_gencfg)
add_dependencies(costmap_2d costmap_2d_gencpp)
add_executable(costmap_2d_markers src/costmap_2d_markers.cpp)
add_dependencies(costmap_2d_markers visualization_msgs_gencpp)
target_link_libraries(costmap_2d_markers
    costmap_2d
add_executable(costmap_2d_cloud src/costmap_2d_cloud.cpp)
add_dependencies(costmap_2d_cloud sensor_msgs_gencpp)
target_link_libraries(costmap_2d_cloud
    costmap_2d
add_executable(costmap_2d_node src/costmap_2d_node.cpp)
target_link_libraries(costmap_2d_node
    costmap_2d
## Configure Tests
if(CATKIN_ENABLE_TESTING)
  # Find package test dependencies
  find_package(rostest REQUIRED)
  find_package(gtest)
  # Add the test folder to the include directories
  include_directories(test)
  include_directories(${GTEST_INCLUDE_DIRS})
  link_directories(${GTEST_LIBRARY_DIRS})
  # Create targets for test executables
  add_executable(costmap_tester EXCLUDE_FROM_ALL test/costmap_tester.cpp)
  add_dependencies(tests costmap_tester)
  target_link_libraries(costmap_tester costmap_2d ${GTEST_LIBRARIES})
  add_executable(footprint_tests EXCLUDE_FROM_ALL test/footprint_tests.cpp)
  add_dependencies(tests footprint_tests)
  target_link_libraries(footprint_tests costmap_2d ${GTEST_LIBRARIES})
  add_executable(obstacle_tests EXCLUDE_FROM_ALL test/obstacle_tests.cpp)
  add_dependencies(tests obstacle_tests)
  target_link_libraries(obstacle_tests costmap_2d layers ${GTEST_LIBRARIES})
  add_executable(static_tests EXCLUDE_FROM_ALL test/static_tests.cpp)
  add_dependencies(tests static_tests)
  target_link_libraries(static_tests costmap_2d layers ${GTEST_LIBRARIES})
  add_executable(inflation_tests EXCLUDE_FROM_ALL test/inflation_tests.cpp)
  add_dependencies(tests inflation_tests)
  target_link_libraries(inflation_tests costmap_2d layers ${GTEST_LIBRARIES})
  catkin_download_test_data(${PROJECT_NAME}_simple_driving_test_indexed.bag
    http://download.ros.org/data/costmap_2d/simple_driving_test_indexed.bag
    DESTINATION ${CATKIN_DEVEL_PREFIX}/${CATKIN_PACKAGE_SHARE_DESTINATION}/test
    MD5 61168cff9425b11e093ea3a627c81c8d)
  catkin_download_test_data(${PROJECT_NAME}_willow-full-0.025.pgm
    http://download.ros.org/data/costmap_2d/willow-full-0.025.pgm
    MD5 e66b17ee374f2d7657972efcb3e2e4f7)
  add_rostest(test/footprint_tests.launch)
  add_rostest(test/inflation_tests.launch)
  add_rostest(test/obstacle_tests.launch)
  add_rostest(test/simple_driving_test.xml)
  add_rostest(test/static_tests.launch)
  catkin_add_gtest(array_parser_test test/array_parser_test.cpp)
  target_link_libraries(array_parser_test costmap_2d)
endif()
install( TARGETS
    costmap_2d_markers
    costmap_2d_cloud
    costmap_2d_node
    DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
install(TARGETS
    costmap_2d
    layers
    LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
install(FILES costmap_plugins.xml
  DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
install(DIRECTORY include/${PROJECT_NAME}/
  DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
  PATTERN ".svn" EXCLUDE
This seems to have nothing to do with gazebo. Maybe in answers.ros.org you will find more help.
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2014-07-23 14:29:16 -0600 )edit
Yeah! But the very same question have already been asked here, so I thaught that someone will perhaps be able to help me http://answers.gazebosim.org/question/3608/gazebo-19-fatal-error-pclconversionsh-no-such-file/
Moda gravatar imageModa ( 2014-07-24 02:43:42 -0600 )edit
