Passive Joint Problem
asked 2014-08-06 22:30:34 -0600
RoboTN gravatar image
updated 2014-08-06 22:33:25 -0600
Dear all, I want to simulate the passive joint(sping-damper) using in my model. But what i found in the joint setting is just <damping> tag, without stiffness tag as expected. Any suggest to that idea? Thank so much!
Here my joint:
<joint type='revolute' name='Joint'>
 <pose>0 0.0 0.0 0 0.0 0</pose>
 <child>LowerSg</child>
 <parent>UpperSg</parent>
 <axis>
  <xyz>0 1 0</xyz>
      <dynamics>
       <damping>0.0000</damping>
       <friction>0.0000</friction>
      </dynamics>
 </axis>
answered 2014-09-02 14:15:19 -0600
scpeters gravatar image
We added spring stiffness tags to gazebo 3.1 in pull request 1117. See the changes to the springdampertest.world for an example of the syntax.
answered 2014-08-07 05:00:00 -0600
AndreiHaidu gravatar image
hi,
there is a stiffness tag as well, see here, however it says that only SimBody supports it.
thanks for your answer. but unfortunately, i'm using ODE lib. Hic.
RoboTN gravatar imageRoboTN ( 2014-08-07 08:49:55 -0600 )edit
Is there any other solution?
RoboTN gravatar imageRoboTN ( 2014-08-07 09:37:03 -0600 )edit
Asked: 2014-08-06 22:30:34 -0600
Seen: 1,517 times
Last updated: Sep 02 '14
