Problem with the packet of ROS Hydro
asked 2014-08-07 07:27:21 -0600
updated 2014-08-11 10:11:27 -0600
I'm using the ROS packet of Gazebo:
http://gazebosim.org/tutorials/?tut=ros_installing
sudo apt-get install ros-hydro-gazebo-ros-pkgs ros-hydro-gazebo-ros-control
But have problems when used:
roscd
rosmake
rosrun gazebo_ros gazebo
say:
roscd: no se encontró la orden
rosmake: no se encontró la orden
I have included this instruction in the .bashrc
source /opt/ros/hydro/setup.bash
When use "cd" and "make", example:
cd ~/NAO/nao_gazebo_plugin
~/NAO/nao_gazebo_plugin$ make
make: *** No se especificó ningún objetivo y no se encontró ningún makefile.  Alto.
I don't have problems with:
rosws init
rosws set
I want to know how I can solve this problems
A lot of thanks!!
<@nkoenig.,p>@nkoenig.,</p<>>
vncntmh gravatar imagevncntmh ( 2014-08-10 08:24:29 -0600 )edit
The link you posted makes no reference to the now outdated rosmake command. Did the apt-get command above work?
joq gravatar imagejoq ( 2014-08-13 10:48:10 -0600 )edit
answered 2014-08-13 15:56:17 -0600
Jose Luis Rivero gravatar image
Could you try the following:
apt-get install ros-hydro-ros
. /opt/ros/hydro/setup.bash
And if this is not working, please use pastebin.com to copy the content of:
set
Thanks.
A lot of Thank!! The problem is Solved!! :)
vncntmh gravatar imagevncntmh ( 2014-08-19 08:25:38 -0600 )edit
answered 2014-08-09 08:27:18 -0600
Henrique Nery gravatar image
Did you make source /opt/ros/hydro/setup.bash?
Normally you cant use those commands if you forget it. As said in tutorial, i suggest you to put it in .bashrc, so it will be done automatically every time you open a terminal.
Best Regards, Henrique
Hello! I have using this instruction and it's included into .bashrc.
A lot fo thankes!!
vncntmh gravatar imagevncntmh ( 2014-08-10 08:22:38 -0600 )edit
It's solved or not?
Henrique Nery gravatar imageHenrique Nery ( 2014-08-10 09:26:10 -0600 )edit
I had already using this instruction and its included into .bashrc.
And the problem continues.
vncntmh gravatar imagevncntmh ( 2014-08-11 09:48:10 -0600 )edit
Asked: 2014-08-07 07:27:21 -0600
Seen: 733 times
Last updated: Aug 13 '14
