2
A simple question on changing bounce properties
asked 2013-01-11 16:30:07 -0600
Ben B gravatar image
updated 2013-01-11 16:32:03 -0600
Hi all,
I'm trying to model a ball. I'm not having any luck with making it bounce. I try to set the restitution coefficient in my URDF code, but when I look at the properties of the ball in Gazebo (ball1 -> ball -> link -> collision -> surface) the restitution_coefficient is still equal to zero.
I'm running Fuerte (which should correspond to Gazebo 1.0.2) on Ubuntu 12.04.
The URDF:
 <robot name="my_ball">
  <link name="ball">
      <origin xyz="0 0 0" />
      <mass value="0.0027" />
      <inertia  ixx="0.00000072" ixy="0.0"  ixz="0.0"  iyy="0.00000072"  iyz="0.0"  izz="0.00000072" />
    <visual>
      <origin xyz="0 0 0"/>
        <sphere radius=".040" />
    <collision>
      <surface>
           <bounce restitution_coefficient = "1"/>
      </surface>
  <gazebo reference="ball">
    <kd value = "100">
    <kp value = "999999">
        <mu1>1</mu1>
    <mu2>1</mu2>
</robot>
I'm loading the ball using:
rosrun gazebo spawn_model -file `pwd`/ballmodel.urdf -urdf -z 10 -x 1 -y -2 -model ball1
I've also tried a few different tags for the restitution coefficient including:
<surface>
<bounce restitution_coefficient="0.5" threshold="0.00"/>
</surface>
And:
<surface>
  <bounce>
       <restitution_coefficient="1"/>
   </bounce>
</surface>
and:
<surface>
   <bounce>
       <restitution_coefficient> 1 </restitution_coefficient>
    </bounce>
</surface>
@Ben B which URDF code worked finally?
peshala gravatar imagepeshala ( 2014-05-21 01:52:04 -0600 )edit
6
answered 2013-01-11 20:06:43 -0600
scpeters gravatar image
updated 2013-01-11 20:07:55 -0600
There's 3 parameters that must be set to enable bouncing. restitution_coefficient must be greater than 0, the bounce threshold must be small, and max_vel must be greater than zero.
Gazebo computes the relative velocity between two bodies in contact. If the relative velocity normal to the contact surface is greater than the bounce threshold, then a bounce may occur, but the bounce velocity will be limited by the max_vel parameter.
Here's an example sdf file that works in gazebo 1.3:
<?xml version="1.0" ?>
<sdf version="1.3">
  <world name="default">
    <include><uri>model://ground_plane</uri></include>
    <include><uri>model://sun</uri></include>
    <model name="ball">
      <pose>0 0 10.5 0 0 0</pose>
            <sphere>
              <radius>0.5</radius>
            </sphere>
          <surface>
            <bounce>
              <restitution_coefficient>0.5</restitution_coefficient>
              <threshold>0</threshold>
            </bounce>
            <contact>
              <ode>
                <max_vel>10</max_vel>
              </ode>
            </contact>
          </surface>
            <sphere>
            </sphere>
            <script>
              <name>Gazebo/Grey</name>
            </script>
  </world>
2 followers
Asked: 2013-01-11 16:30:07 -0600
Seen: 3,199 times
Last updated: Jan 11 '13
